compaq 6510b chaging issue
    i have compaq 6510b that will not power on with charger but can work fine with a charged batt, little check done q507- s=19v, d=17.5, d=0v pls kindly guide me to fix the fault
    Re: compaq 6510b chaging issue
    Check the Voltage in U5 8.9.26.5.29.22.4.27
    check the Voltage in Q539 pin 1.2.3 & D12 pin1.2
    Check your Adapter 90W
    Check U14 pin 74 ADP_PRES
      q539 pin 1,2,3=18.0v d12=17.8v
      u5 pin8, 9.26.5.29.22.4.27 =0v
      pin 74 = 0v
        DC jack pin 3 LIMIT_SIGNAL ? Q507 pin4 Gate Voltage is to high 18V to bypass it should be less than 10V , test Q507 for any short G/D/S
          q507 not short but g=17v
            DC jack pin 3 LIMIT_SIGNAL ? Test Q514 for any short as well
              LIMIT_SIGNAL trace to q22 S=5.6V, D=0V, G=0V
              Q514 NOT SHORT
                remove Q507 put the multimeter Diode mode value S.D.G
                test all pins of Q545
                  q507 removed S=18.2V, G17.6V D=0V
                  Q545 B=16v C&E=0V
                    Check u6(lm393)
                      Originally posted by smali View Post
                      Check u6(lm393)
                      THANKS BRO AFTER REPLACING U6, all seem ok but still not coming up , i found out there is short pin 19 of u28. i replace c336, remove use u28 but short remain plz
                        thats bad. +V3AL is on many lines. try to inject voltage to find bad component faster
                          follow the ktmmotocross insturction inject external 3v with high amps on the short line and observe the pcb the faulty component will be heatup....i think your smsc kb1070 may be faulty...
                            after injecting my u14 become very hot
                              NO HIGH AMPS!!!
                              with 3V put max 2A =6W and rise it if u cannot find component. if u put 5 or higher amps u can burn component and WELDING COMPONENTS LEG TO PAD which is way harder to repair
                                remove it and check if short is gone. than measure its pads for short to check if it have internal short or some of its output is shorted
