Card Reader to USB wiring help please
  • IamPritesh
    • Aug 2017
    • 354
    • India
    So i have this Compaq Presario C700 whose USB does not work. It has 5V and powers up the usb device but end us as unrecognized device.
    Upon checking the out of the two data signal only one has 3.3 volt and the other one no voltage at all.
    The card reader does work as it should. I was hoping if someone knows how to make a wiring so we can use the card reader data lines work with USB.
    Appreciate your help. Thanks
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3573
    • slovakia
    Re: Card Reader to USB wiring help please
    look at the schematic
    find it by board code
    • IamPritesh
      • Aug 2017
      • 354
      • India
      Schematic attached but I am not sure how to do this.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3573
        • slovakia
        this is maintenance manual not schematic
        put board code to google
        • IamPritesh
          • Aug 2017
          • 354
          • India
          Sorry about that. Uploaded the correct schematic.
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3573
            • slovakia
            on page 27 find your connector and check its state
            • IamPritesh
              • Aug 2017
              • 354
              • India
              OK the Card reader does not work however the webcam, does work. Has anyone ever successfully repaired a USB using Webcam data signals ?
              Do yo just connect the data lines of webcam to data lines of usb ? I am sure there must be more to it. I dont want to ruin a working laptop with wrong wiring . Please help.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3573
                • slovakia
                all usb have the same lines. if one of yours reader is missing, and connector is good than u have bad ICH or cracked ball under it
                • IamPritesh
                  • Aug 2017
                  • 354
                  • India
                  The reader and the USB is not working. All have +5V and the usb has data+ but no data- signal. I suspect it is the the ICH. However the webcam is still working fine which also gets the signal data+ and data- from the ICH. I was hoping we can have a hack that would enable the USB using these webcam signal.
                  I have heard someone on this forum do it, just dont remember who.
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3573
                    • slovakia
                    webcam is just another usb device. see lines at bottom of page 20
                      Alcor AU6368 USB 2.0 Flash Memory Card Reader Datasheet
                      The AU6368 is an integrated single chip memory card reader controller specially designed for notebook, hand-held and other PC peripheral devices, which require fewer components for small PCB area. It supports a widely used flash memory card such as CF, MD, SMC, xD Picture Card, MS, MS Pro, MS Duo, SD and MMC. It can be used as removable storage disks in enormous data exchange applications between PC and PC or PC and various consumer electronic appliances.
                      The AU6368 reads digital content saved on memory card that user captured with the portable device such as notebook, digital camera,...
                      10-23-2024, 03:26 AM
                    • vbogoev
                      Read eMMC chip using SD card reader
                      by vbogoev
                      I found several sources where guys successfully read eMMC chip using a SD card reader. I was interested to try it, just to practice micro soldering, but for some reason I am unable to read the chip. The chip is known working one (desoldered from an old working device) model Samsung KLM8G1WE4A-A001. The card reader is Transcend USB 3.0. So basically I've connected everything as it is described in the schematic, but the sd card reader didn't even start to blink. I am not sure what I am missing, so I'll appreciate some help... ...
                      07-08-2023, 10:47 AM
                    • Technomancer
                      Nintendo 2DS SD Card Reader issue. Problem on the clock line?
                      by Technomancer
                      I have a 2DS that I am working on that has a problem reading SD cards. It knows that card is in the slot (which, means the detect pin is working anyway) but it says it can’t read the card.
                      Here is what I have done so far:
                      -Tried SD card in another 2DS and on PC, works great.
                      -Tried piggybacking another SD card slot (just so I didn’t have to take the other one off), same issue.
                      -Compared voltage drop readings from a working 2DS to the faulty one. All reads are very close except one, the 7th pin from the left, with the pins closest to you, which I believe...
                      06-07-2022, 09:01 PM
                      Apple MacBook Pro A1212 820-2060 USB Audio Card Reader Power Boardview
                      Apple MacBook Pro A1212 820-2060 USB Audio Card Reader Power Boardview...
                      10-27-2024, 07:21 AM
                    • Christos Tsiligiannis
                      Marian Trace Alpha sound card repair help
                      by Christos Tsiligiannis
                      Hello to the forum.
                      My name is Christos, I am new to the forum here and i am posting from Greece.
                      So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                      To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                      So i tried asking for a schematic from the company and they would not give me one. Instead they...
                      11-18-2024, 05:26 AM
