Alcor AU6368 USB 2.0 Flash Memory Card Reader Datasheet
    The AU6368 is an integrated single chip memory card reader controller specially designed for notebook, hand-held and other PC peripheral devices, which require fewer components for small PCB area. It supports a widely used flash memory card such as CF, MD, SMC, xD Picture Card, MS, MS Pro, MS Duo, SD and MMC. It can be used as removable storage disks in enormous data exchange applications between PC and PC or PC and various consumer electronic appliances.
    The AU6368 reads digital content saved on memory card that user captured with the portable device such as notebook, digital camera, MP3 player, PDA and mobile phone… etc. In addition, AU6368 allows user to transfer information such as data, graphics, texts or digital images from one electronic device to another quickly and easily. Furthermore, AU6368 integrates power switch function; manufacturers can use fewer components in their product design.
    With AU6368, user experience will be also further enhanced by the Plug-and-Play nature built into latest operation systems such as Windows 2000/XP and Mac OS X.
    Features
    - Support USB v2.0 specification and USB Device Class Definition for Mass Storage, Bulk-Transport v1.0
    - Support CF/MD, SD/MMC, MS/MS PRO/MS ROM/MS Duo AND xD/SMC specification - Work with default driver from Windows ME, Windows XP, and Mac OS X. Windows 98, Windows 2000 are supported by vendor AP (The AP included both win98 and 2000 driver) from Alcor.
    - Ping-pong FIFO implementation for concurrent bus operation - Support multiple sectors transfer optimize performance - Support slot-to-slot read/write operation.
    - Support auto-detecting slot with card inserted on Win 2000 without driver.
    - Capable of handing 4 sets of built-in PID, VID and strings to minimize inventory control and improve lead production lead-time.
    - Support LED for bus activity indication.
    - Each slot can be enables/disabled by 5 independent pins to fit all the different card readers combination requirement.
    - Runs at 30MHz, built-in 480 MHz PLL - Built-in 3.3V to 2.5V regulator
  • ekozeko333
    by ekozeko333
    🧠 What I’ve Done So Far
    Flashed...
    06-21-2025, 02:48 AM
  • corrize
    Nikon D800 camera - flash don’t work and capacitor don’t charge
    by corrize
    Hello, I'm stuck in troubleshooting…
    The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
    In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
    When I press the flash button, it's detected by the system, flash icon appear on LDC display....
    10-01-2022, 10:02 AM
  • Christos Tsiligiannis
    Marian Trace Alpha sound card repair help
    by Christos Tsiligiannis
    Hello to the forum.
    My name is Christos, I am new to the forum here and i am posting from Greece.
    So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
    To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
    So i tried asking for a schematic from the company and they would not give me one. Instead they...
    11-18-2024, 05:26 AM
  • Kemer
    Graphics Card mounting frame
    by Kemer
    Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
    As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
    I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
    What worries me right now is the possibility that...
    09-14-2024, 08:57 AM
    HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
    This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
    09-06-2024, 08:30 AM
