HP 650 plugged in not charging
  • invisible4u4ever
    • Aug 2015
    • 23
    I have one hp 650 with notification plugged in not charging, I check plus on battery connector when battery is plugged in and have 12v on + ... when laptop is off and put 12v from power supply I have 12v and 1.8A power comsuption but when charger is plugged in on power supply I have only 0.1A ...
    Does anybody have idea what to check
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Re: HP 650 plugged in not charging
    offcourse first two mosfets and charging ic
    • invisible4u4ever
      • Aug 2015
      • 23
      Something strange is happening when i put dc power supply on output of second mosfet... amps compsumtion goes to 2.1A and go to zero and again to 2.1A ...
      I didn't check charging ic
      • invisible4u4ever
        • Aug 2015
        • 23
        but why i have 12v on + of battery connector and battery not charging ... that is strange to me...
        • on/off
          • Oct 2016
          • 333
          • Indonesia
          There could be mosfet shorted on area charging circuit. especially High side mosfet. (Drain-to-Source)
          Also would be help if you mention mainboard ID. So, we have same a reference
          • invisible4u4ever
            • Aug 2015
            • 23
            This is schematic
            • invisible4u4ever
              • Aug 2015
              • 23
              Changed charging circuit and everything is working fine.
              Thanks everyone
              • invisible4u4ever
                • Aug 2015
                • 23
                hahah after 15min again same problem... charging and after one sec not charging... loop I dont know where and what to check
                • on/off
                  • Oct 2016
                  • 333
                  • Indonesia
                  Make sure use original hp adapter and have known good battery. Try replace Q0901 and Q0902.
                  • invisible4u4ever
                    • Aug 2015
                    • 23
                    aaaa check this... when I was heating first fet .... i try again and after that charging is off no going on... i check capacitor on gate of first fet and that capacitor is short to ground after that I replace that capacitor and check again charging is fine for now...
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3628
                      • slovakia
                      "when i put dc power supply on output of second mosfet"
                      u diid not read forum?
                      why do u thing this is two mosfets to turn on power?
