MPM mode - "SYSTEM BOARD 00A"
  • efendy
    • Jan 2019
    • belgium
    I am new to this forum and this is my first message,
    for info, I am Belgian so sorry for my english
    I have an Elitebook 8740w. since I updated my BIOS, I have an error message at startup "SYSTEM BOARD 00A" - System configuration ID
    I have the BIOS version 68CAD ver. F. 60 of 11/10/2015, my motherboard is 1520 KBC version 33.32.
    So I read dozens of pages on the net, watched dozens of videos on the net but I can not do it. I spent 2 evenings and I'm losing patience trying to solve
    I'm trying to run Wndmifit64.exe (notebook DMI Firmware interface tool, I'm getting the error "this system board is not supported, will not be able to set bios settings" and "MPM is not unlocked ...."
    So, I am the instructions of the HP guide "DMI programming for consumer notebooks
    For this to work, activate the MPM mode. So, I'm doing a bootable USB key with the Nbdmifit file.
    I run the USB key in UEFI mode ... finally I receive the error "this platform is not supported" therefore impossible to activate the mode MPM.
    I'm still trying to run nbdmifit.bat..I'm introducing the date and I have the message "TPM is OFF" (I think TPM = MPM).
    I contacted HP support, they report that my computer is too old (2011) and that they can not give me any assistance
    please help me
    Can you tell me exactly what I need to do
    Thank you
  • efendy
    • Jan 2019
    • belgium
    Re: MPM mode - "SYSTEM BOARD 00A"
    In the guide, it is also mentioned that you need the "hp system board replacement & system diagnostic tool" which contains the following files:
    BIOS_0018.zip
    grbinst.exe
    hp_tools_0018.zip
    ionic.zip.dll
    makebootableDMI.exe
    I did not find these files in the "NbDmiFit_2.10.zip"
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3626
      • slovakia
      according to this wideo u must first flash new bios and than use dmifit
      https://www.youtube.com/watch?v=PqLqgSB_GNw
      give it a try
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • DynaxSC
        Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
        by DynaxSC
        I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
        I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
        Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
        Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
        05-04-2025, 12:08 PM
      • spantor
        Activate power board Philips 40PFH40009/88 tv
        by spantor
        Hello partners.
        Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
        The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
        02-11-2024, 05:07 PM
