Lenovo S230U does not power on.
  • soker
    • 3
    Hello! I need help please.
    The Board Compal LA-8671P Rev 1A_1004A does not turn on. green LED lights, Battarie is charged, 3vLDO and 5vLDO are there. When pressing on the switch, the fan turns for 4 seconds and then it is out again.
    measured voltages:
    + VCC_GFXCORE_AXG = 0V
    + CPU_CORE = 0V
    when i press the switch, PM_SLP_S3 #, PM_SLP_S4 #, PM_SLP_S5 # rises to 3.2 V and then immediately back to 0V
    + 3vs, + 5vs, + 1.05VS, + 1.8VS, + 1.5VS, + 0.75VS only appear if PM_SLP_S3 #, PM_SLP_S4 #, PM_SLP_S5 # are set to 3.2V.
    + USB_VCCA = 0 v
    Measurements on PU901
    VCC = 5.01v (when I press the switch, otherwise it is at 0v)
    VR_ON = 3.2v (if I press the switch, otherwise it is at 0v)
    CPU_B + = 20,1V
    VRMP (pin 10) = 20v
    VR_HOT # = 1.05v (if I press the switch, otherwise it's at 0v)
    VGATE = 3,3v (if I press the switch, otherwise it is at 0v)
    PVCC = 5.01v (when I press the switch, otherwise it is at 0v)
    HGA = 0v
    HG1 = 0v
    VR_SVID_CLK = VR_SVID_ALRT # = 1,05v
    VR_SVID_DAT1 = 1.05v
    Measurements on PCH
    PCH_PLTRST # = 0v
    SYS_PWROK = 3,3v
    EC_RSMRST # = 3.2v
    PCH_RSMRST # = 3.2v
    + 3V_PCH = 3.3v appear all the times
    + 5V_PCH = 5v appear only for a few second
    listen to this links, it show how the board ist doing: https://youtu.be/sG1rC-Rfsl8
    MOD EDIT: Link to schematic -> https://www.badcaps.net/forum/troubl...671p-schematic
    Thanks for your help.
  • Weelcup
    TopTech
    • Oct 2017
    • 307
    Re: Lenovo S230U does not power on.
    Hi
    Did you flash the bios? If so, did you back up its original bios?
    • caspian
      • Oct 2015
      • 1591
      • Laptop
      it seems PU901 and/or its connected Mosfets are defective. First, test PQ1001 to PQ1006 for being shorted or being defective. I addition, check all pins of PU901 for bad voltage or being shorted. all the other components of your laptop seem fine.
      • soker
        • 3
        hello,
        thank you a lot for the reply,
        i check PQ1001 to PQ1006 but i did not found any short.
        here are the resistence values of the Pins with respect to Ground
        the values in the parenthesis are the Voltages:
        ( When i plug in the charger / when i press the power button )
        PQ1001
        pin 1, 2, 3 = 0 ohm (0v/0v)
        pin 4 = 8,5 ohm (0v/0v)
        pin 5, 6, 7, 8 = 3,8 ohm (0v/0v)
        PQ1006
        pin 4 = openline (0v/0v)
        pin 5, 6, 7, 8 = 2 ohm (0v/0v)
        PQ1002
        pin 1, 2, 3 = 3,8 ohm (0v/0v)
        pin 5, 6, 7, 8 = openline (20v/20v)
        PQ1005
        pin 1, 2, 3 = 2 ohm (0v/0v)
        here are the resistanve values and voltage on PU901
        pin 13 = 10 ohm
        pin 24 = 3,8 ohm
        pin 32= 4,9 ohm
        pin 33 = 3,9 ohm
        pin 35 = 0 ohm it is Ground
        pin 42 = 2 ohm
        pin 49 = 2 ohm
        pin 60 = 1,7 ohm
        all oder pins are over 50 ohm.
        i am getting following voltages
        pin 10 = (20v/20v)
        pin 1, 2 = (4,9v/4,9v)
        pin 48= (0v/4,9v)
        pin 49= (0v/0v)
        pin 46= (0v/0v)
        pin 45= (0v/0v)
        pin 24= (0v/0v)
        pin 13= (0v/0v)
        pin 12= (0v/3,2v)
        pin 11= (0v/0,9v)
        pin 4= (0v/3,2v)
        pin 36= (0v/5v)
        VR_SVID_CLK=VR_SVID_ALRT#=VR_SVID_DAT1= 1,05v the only apear when the board is trying to start.
        schould the voltage not appear at CSREFA (Pins 49) and CSREF (Pins 49) when i plug in the charger? may be PU901 musst first provide these Reference Voltage
        • soker
          • 3
          hello Weelcup,
          i did not flash the Bios.
          how can i check it using the mutimeter?
          • caspian
            • Oct 2015
            • 1591
            • Laptop
            the problem is not related to CSREFA and CSREF . your resistance readings are very low. Ich glaube PU901 und PQ1001 bis PQ1006 sollten alle ersetzt werden. aber es kann teuer werden.
            • Weelcup
              TopTech
              • Oct 2017
              • 307
              Originally posted by soker
              hello Weelcup,
              it doesn't need to be checked via multimeter. I just wanted to exclude the bios from the equation as I had a problem of shutting down in seconds with bios issue. but as much as it is the original then no worries.
              I agree with #Caspian. your resistant readings are low.
              • soker
                • 3
                hey i disconect PL1001 and PL1004 and check the values of resistances.
                for PL1001
                on the Mosfet site i have 2 kohm and the oder site 4 ohm
                for PL1004
                on the Mosfet site i have 2 kohm and the oder site 2,3 ohm
                on PU901 i get
                Pin 24 = 4ohm
                Pin 32 = 2kohm
                Pin 33 = 2kohm
                Pin 34 = 110kohm
                Pin 41 = 110kohm
                Pin 42 = 2kohm
                Pin 43 = 68kohm
                Pin 49 = 2,4ohm
                when i press the power and check the voltage , i some time get 0,9 v on pin 1,2,3 of PQ1002 and 0,3v on pin 1,2,3 of PQ1005.
                i also purchace a new PU901 and PQ1001 to PQ1006 the will comw latter
                do you think that the PCH and CPU coud be defekt? because the have a low resistance on the line +CPU_CORE and +VCC_GFXCORE_AXG?
                i dont anderstand what the following instruction meant (Choke PN:SH00000JX00
                DCR=1.33~1.396m ohm) ist is on page 48 of the schematic. pleace could you explane me that?
                thank you!
                • soker
                  • 3
                  hey
                  I read on internet that one of the Bios-chip must have Voltage on the Pin 3 and 8 when i only plug in the charger but dont power the Board. is it true?
                  in this case with BIOS-chip must have the Voltage before i power the board?
                  thanks
                  • Conste
                    • Oct 2018
                    • 235
                    Yes that is right. BIOS Chip and KBC / Super I/O must habe 3,3v to start the device, as far as I know actually
                    KBC seems to have 3,3v in your case
                    • on/off
                      • Oct 2016
                      • 333
                      • Indonesia
                      hey
                      thanks
                      It's depend what them design, when KBC have 3.3V from +3VLP. That enough to power KBC and give command to any regulator to power up. While supply for bios come from switching 3ALW to 3VS need triggering from SUSP signal. (this signal appear after pressing on/offbtn#).
                      Already you've prove that VS voltage present even only momentary
                      • caspian
                        • Oct 2015
                        • 1591
                        • Laptop
                        I was busy these days. Sorry that I could not answer early. It seems that the CPU is defective and the PU901 circuit is fine. Before buying or replacing PU901 , if you have got a BGA machine, remove the CPU. solder PL1001 and PL1004 back on the mainboard. then measure voltage on these coils again. Unfortunately, the CPU is soldered. So testing the circuit gets difficult. Do not replace PU901 and the Mosfets.
                        • piernov
                          • Jan 2016
                          • 4439
                          • France
                          Usually CPU VCore will not be produced if the CPU doesn't request it. (to the CPU buck controller through SVID). Also, VCCGFX is usually produced only after BIOS is running, and in several cases it requires the internal display to be recognized.
                          Before the CPU can request CPU VCore, UNCOREPWRGOOD has to come high, meaning VCCSA and VCCIO are good. On this platform you can measure it on R28. On some platforms it's not available to measure, so you have to rely on the signals that come up before like SYS_PWROK or PCH_PWROK.
                          Better try to replace PU901 before trying to desolder CPU, but this rarely solves the issue on those platforms. Even more so on Haswell and newer where the CPU die way more easily than earlier platforms.
                          Also make sure there's no knocked off component or liquid damage near PU901 circuits.
                          Also make sure the 25Mhz PCH clock is ok.
                          PS: didn't read the whole thread so sorry if I missed something…
                          • caspian
                            • Oct 2015
                            • 1591
                            • Laptop
                            that us right. It is possible that both the CPU and the PU901 circuit be fine. In that case, desoldering the CPU and PU901 is useless. So make sure before doing any desoldering.
                            • RJARRRPCGP
                              • Jul 2004
                              • 6304
                              Are you sure you don't mean Skylake or newer?
                              Skylake was when Intel was confirmed to have the ultra-thin layer that easily bent under heatsinks, LOL. It's thinner than even Haswell!
                              ASRock B550 PG Velocita
                              Ryzen 9 "Vermeer" 5900X
                              Arc A770 16 GB
                              eVGA Supernova G3 750W
                              Alienware AW3423DWF OLED
                              • soker
                                • 3
                                thank you all for the reply.
                                i check some voltage like @piernov said and i found this
                                SYS_PWROK = 3,2V when i press the power else it is 0v
                                PCH_PWROK =3,2V when i press the power else it is 0v
                                VCCSA = VCCIO = 1,05 V when i press the power else it is 0v
                                H_CPUPWRGD = 0 V when i press the power it is still 0 V and is not shorted
                                look at this video: https://youtu.be/sG1rC-Rfsl8
                                  Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                  This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                  09-06-2024, 05:30 AM
                                • Natob82
                                  Micro Momentary Push Switch?
                                  by Natob82
                                  Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                                  12-21-2022, 05:22 AM
                                • SluggerB
                                  Help making a switch work the opposite way with a relay
                                  by SluggerB
                                  I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                                  I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                                  It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                                  02-07-2025, 07:57 PM
                                  Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
                                  by sam_sam_sam
                                  Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
                                  ( needs more cam circuits for the machine to work correctly again )
                                  https://www.ebay.com/itm/275321870186
                                  To
                                  3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
                                  ( not 4 positions but the right amount of cams circuits )
                                  https://www.ebay.com/itm/274660439950
                                  I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
                                  03-18-2023, 05:12 PM
                                • Woodsworth
                                  PS3 CECHC03 60GB YLOD Troubleshooting
                                  by Woodsworth
                                  I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
                                  START
                                  Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
                                  03-19-2024, 07:58 AM
