Lenovo Z50-70 crashes when charger connected, erratic working on battery
  • kronikus
    • Feb 2015
    • 74
    • Croatia
    my Lenovo Z50-70 NM-273 with Intel i5 and Nvidia N15 discrete graphics work only on battery. And even on battery it is not predictable how long it will last before crashing. Sometimes work for whole hour, sometimes 5 minutes, regardless of what I'm doing.
    Same is happening no matter what windows is installed. Curretntly it is on Win 7 64bit, all drivers are installed without any problem - chipset, both graphics etc. Laptop does not overheating, it's clean and with new thermal paste. Furmark works just fine and temperature does not exceed 65 degrees.
    Everything seems OK and, for no reason, laptop crash and stays off. Without restarting. Every time. No BSOD, no any error message.
    Other problem is that when power adapter is plugged, it crashes instanly.
    I can power it again with power adapter, but it crashes in shorter intelval every time. For example, it works on power for 5 minutes an crashes, than next time works for 3 minutes etc. At last, it can not even start.
    When laptop is off, baterry charging works fine.
    Does anyone have experince with that specific problem?
    I have schematics but no boardview.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo Z50-70 crashes when charger connected, erratic working on battery
    Gpu issue??
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3628
      • slovakia
      check voltages on both side of PQ302, PQ303, PR306 when connected and disconnected charger
      • kronikus
        • Feb 2015
        • 74
        • Croatia
        It passed all graphic tests, works steady 30+ minutes on Furmark. Official drivers for Intel and Nvidia gpu are installed without any problems. Passed dxdiag. Passed Lenovo diagnostic on all components. Maybe the most important fact is that laptop crashes instantly when charger is plugged in? Every time. Even without hard disk. Can that be related to graphics?
        • kronikus
          • Feb 2015
          • 74
          • Croatia
          Ok, I'll do measurements on PQ 302/303 and PR306.
          • kronikus
            • Feb 2015
            • 74
            • Croatia
            On battery, turned off:
            Drain/Source/Gate
            PQ302 15.2/14.8/14.5
            PQ303 15.2/.15.2/0
            PR306 0(VIN side)/0(diode side)
            On battery, turned on:
            Drain/Source/Gate
            PQ302 15.3/14.9/14.6
            PQ303 15.2/15.2/0
            On charger with battery, turned off:
            Drain/Source/Gate
            PQ302 20/20/5
            PQ303 16/20/20
            PR306 20(VIN side)/0 (diode side)
            On charger and battery, when turned on and than removed battery, PQ303 Drain stay 16.8V untill turned off. Than drops to 0.8V and stay 0.8V unill battery reconected, when jumps to 16.8.
            Again, when battery was removed during work, Drain stay at 16.8V untill turning off by power button or crashing.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3628
              • slovakia
              pr306 was mistake. i mean pr316
              • kronikus
                • Feb 2015
                • 74
                • Croatia
                On both side of PR316 voltages are same as on the Drain of PQ303.
                Voltage drop across some coils:
                PL303 8.2mV; PL304 9.9mV; PL307 1.7mV; PL701 5.9mV; PL9 6.9mV.
                • kronikus
                  • Feb 2015
                  • 74
                  • Croatia
                  Some tests. I removed RTC battery so don't pay attention to the time.
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Sounds like no crash, just straight to shutdown. (power loss)
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3628
                      • slovakia
                      did u try another charger?
                      • kronikus
                        • Feb 2015
                        • 74
                        • Croatia
                        Yes, It is power loss. Laptop suddenly turns off and stay off.
                        I tried another charger and other battery, too. Nothing changed.
                        • Gurmit
                          • May 2020
                          • Singapore
                          Hi did you find the problem? I am having similar issues with my Z50-70 laptop.
                          • acshud
                            • Sep 2017
                            • 106
                            • romania
                            i have a same problem.advice
                            • flat-earther
                              how to prevent a connected charger from draining battery when not charging?
                              by flat-earther
                              I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                              So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                              but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                              So the battery is backfeeding the charger and being drained.
                              How can I prevent...
                              08-07-2025, 01:04 PM
                            • master_haze86
                              820-01958-A no power sys led = white when charger is connected.
                              by master_haze86
                              Hi everyone.
                              First, let me preface by saying that I do not have much experience with diagnosing damages in motherboards other than visual inspection and checking simple short to ground faults.
                              But I do learn quickly, and really want to learn how to properly diagnose motherboard faults. If someone could have the patience to go over this board with me, it would be greatly appreciated.
                              A customer came into my shop with a A2179 MacBook with an 820-01958-A logic board. The reason for bringing the laptop in is that the laptop stopped turning on.
                              First thing...
                              02-15-2024, 05:30 PM
                            • nikolayu
                              Dell Latitude 5420 wont turn on when charger is connected
                              by nikolayu
                              I have Latitude 5420 that it's working fine on battery but when it's plugged on USB C charger it wont turn on.
                              Battery is charging fine. Also, if I connect the charger while laptop is on, everything is fine, it will charge.
                              The same thing if I connect to other USB C port.
                              Charger is OEM
                              03-13-2024, 12:34 PM
                            • Julian Bailey
                              HP ProBook 445 G8 Battery not charging
                              by Julian Bailey
                              Hi all
                              We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                              The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                              I have gone around the board with a MM and cant find anything
                              Windows shows the battery fine,...
                              10-11-2024, 10:34 AM
                              NVDC charger configuration...
                              11-05-2024, 03:28 PM
