HP 450 G0 Charging port blinking
  • DeniS182
    • Jun 2014
    • 328
    • Slovakia
    I have problem with this laptop. Only LED on charging port blinking. There is no 3.3V voltage on bios chip. Please help me identify chip from the picture and upload schematic if someone have. Thanks.
    MB:
    Fi Ji MB
    12238-1
    48 .4yz31.011
    CHIP: E0 FC
    edit: It is EQ FC - RT8223M
    1. 0V
    2. 0V
    3. 2V
    4. 2V
    5. 0V
    6. 0V
    7. 0V
    8. 3.3V
    9. 4.5V
    10.0V
    11. 0V
    12. 0V
    13. 5.2V
    14. 3.3V
    15. 0V
    16. 18.5V
    17. 5V
    18.0.4V
    19. 0V
    20. 0V
    21. 0V
    22. 4.5V
    23. 0V
    24. 0V
  • DeniS182
    • Jun 2014
    • 328
    • Slovakia
    Re: HP 450 G0 Charging port blinking
    I have 3.3V always power here, on power button also. I don't have voltage on the bios chip, I don't know why. Have someone schematic please? I found only similliar schematic, I attached it.
    When I inject 3.3V to bios chip, LED on charging port blink and stay off, but after press power button nothing happen.
    • Techtiger
      • Oct 2014
      • 1601
      • france
      R2509 Out side you should get 3D3V_AUX_S5 from Pin 8 RT8223MZQW 5/3 Volt regulater LDO3 inside of R2509 connected to Bios chip 1 pin 8/3 Bios2 pin8/3 3.3v
      • DeniS182
        • Jun 2014
        • 328
        • Slovakia
        I know but schematic is different, I have only one bios here and I can't find this resistor.
        I found two resistors connected to 8pin of bios chip,near them, but there is no voltage on both sides of these resistors.
        One of them is connected from SPI_CS pin to SPI_PWR - in schematic R2517 4k7 but my resistor is bad. I replaced it and connect bios 8pin with wire straight to VREG3, but there is big current consumption because voltage drops to 1V...
        • Conste
          • Oct 2018
          • 235
          Had the same Problem with an HP ProBook 6570b, when I used the original HP charger, the Problem disappeared
          • DeniS182
            • Jun 2014
            • 328
            • Slovakia
            I have new original HP 4.7A charger. And Id PIn on charging port is ok.
            When I inject 3.3v to bios chip current consumptiion is 130mA and when I also connect charger 370mA.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3582
              • slovakia
              https://cdn.badcaps-static.com/pdfs/...b196680b71.pdf
              no pgood signal
              • DeniS182
                • Jun 2014
                • 328
                • Slovakia
                Where can be the problem if this power good signal is missing? Thanks.
                • Techtiger
                  • Oct 2014
                  • 1601
                  • france
                  Originally posted by ktmmotocross
                  PGOOD is an open-drain type output . PGOOD is actively held low in soft-start,standby, and shutdown. It is released when both output
                  voltages relese 3AlWS 5ALWS
                  correct me if i wrong ktmmotocross if he is not getting 3V/5V ALWS it will not generate?
                  • on/off
                    • Oct 2016
                    • 333
                    • Indonesia
                    I would prefer check continuity between pin 8 bios chips to know where is source of power, where that pin is connect?
                    According schematic S-Series Intel Shark Bay as reference, the source connect via resistor R2508/switching or R2509/LDO (both value are 0 ohm or just jumper pad/shorted)
                    DY/light green= not installed.
                    3D3V_S5 =output RT8223M switching
                    3D3V_AUX_S5= LDO of RT8223M.
                    -ADP_DET shoud be high
                    -LID_SW# should be high.
                    Also pin 18 for Enable switching didn't go high. That's why there aren't outputs of IC RT8223 on grey coils.
                    The amperage have approx 130-370mA mean have resistance 9-24ohm, seem to low. Correct me if I wrong to calculate it. Look like this rail have little shorted.
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3582
                      • slovakia
                      if u dont have 3.3 on bios and without bios it have it, than u must have bad bios or some component on that line
                      • DeniS182
                        • Jun 2014
                        • 328
                        • Slovakia
                        LID_SW# - 3.3V
                        ADP_DET - 3.3V
                        bios chip is good and there is no voltage if is bios soldered or not. And from bios 8 pin it comes inside the motherboard.
                        • DeniS182
                          • Jun 2014
                          • 328
                          • Slovakia
                          I can't find where is the problem. Have someone right schematic please? thanks.
                          • DeniS182
                            • Jun 2014
                            • 328
                            • Slovakia
                            Problem was in missing ENC signal on RT8223M after inject 3.3V here notebook works normally.
                            • Techtiger
                              • Oct 2014
                              • 1601
                              • france
                              So ENC enable 2 SMPS plus connected internally to VREG3 , then your RT8223M is faulty in that stage is your 3/5V ALWS output after pressing Power Button? or after inject 3.3v to ENC ? And for the PGOOD signel comes after pressing power button or after 3/5V ALWS ?
                              • DeniS182
                                • Jun 2014
                                • 328
                                • Slovakia
                                I tried replace IC first, but nothing changed. Then I inject vreg3 to ENC pin and notebook works normally. After power button is pressed notebook start and works fine. I put all back together.
                                Thanks for answers.
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3582
                                  • slovakia
                                  did u check pc4517 out of board?
                                  • acedogblast
                                    by acedogblast
                                    11-02-2024, 05:13 PM
                                  • flat-earther
                                    ASUS X54H laptop thinks it's always charging even with charger unplugged
                                    by flat-earther
                                    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                    Windows also shows ''Plugged in'' when charger is not connected.
                                    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                    If I let battery run out and say it has 3% Windows will...
                                    06-24-2025, 09:32 AM
                                  • paparazzo79
                                    USB type C as charging port on laptops
                                    by paparazzo79
                                    Hi guys.
                                    I wanted to purchase HP Elite x2 1012 G2 laptop but I saw that the charging port is type C and I remember Mr.Sorin from electronicsrepair on yt telling that the worse charging port for laptops is type C and on other channels I saw that they mostly fail especially HP Spectre X360, so I assume I should avoid laptops with type C charging port (dunno why) or it just depends on model?
                                    He mentioned that laptop fail because of that port,and simply become dead,and most of the models fail because of that port.
                                    01-25-2023, 09:12 AM
                                    by SMDFlea
                                    Bad...
                                    09-02-2021, 04:40 PM
                                  • BMCappelletti
                                    Asus Chromebox CN62 - wrong chip put on BIOS reader
                                    by BMCappelletti
                                    Long story short:
                                    - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                    - gave the computer to his son a couple years later
                                    - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                    - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                    (seems like the story was not that short)
                                    He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                    01-08-2025, 07:27 PM
