What i3 processors can go in G72
  • pecrie
    • Nov 2011
    • 182
    Hi all ,
    I have this G72 - 120SD with the i3 - 330M CPU withthe HD Graph accelerator on it.
    Can I put in a higher i3 - say a 370M ?? Or maybe even a 390 M ??
    Thanks for your info
    • 21968
    Re: What i3 processors can go in G72
    Check page 95 . http://h10032.www1.hp.com/ctg/Manual/c02641840
    • pecrie
      • Nov 2011
      • 182
      SMDFlea ,
      Thank you.You are a great help here ...
      And some others also
      • Byte_76
        Requesting assistance with 486 motherboard repair
        by Byte_76
        I have a seemingly rare 486 motherboard which shows no signs of life.
        The Motherboard is marked with the labels B887 / 8 / 9 AI, which seems to be a Mecer branded board.
        With an AT power supply hooked up, the power supply turns on but the board does not post, there is no beep and there is nothing displayed on the post analyser card, whether it's plugged into a PCI slot or an ISA slot.
        I found a thread on Vogons of someone else who had the same board in working condition.
        What I've tried so far: (In each case, the symptoms remain unchanged as...
        04-12-2025, 06:43 AM
        Intel i7-6700K i5-6600K i7-6700T i5-6600T i5-6500T i5-6400T i3-6320 i3-6300T i3-6100T Datasheet
        The 6th Generation Intel Core processor, Intel Pentium processor, and Intel Celeron® processor families for the Desktop S-Platform are a 64-bit, multi-core processor built on 14-nanometer process technology. The Desktop S-Processor Lines are offered in a 2-Chip Platform and are connected to a discrete Intel® 100 Series Chipset Family Platform Controller Hub (PCH) chip on the motherboard. See the following figure. This document covers the S-Processor Lines for Desktop (DT).​
        Throughout this document, the 6th Generation Intel Core processor, Intel Pentium processor, and Intel Celeron...
        10-23-2024, 02:46 AM
      • Mila1
        HP 800 mini G4, G5, G6 changing PL1, PL2 via BIOS or hardware
        by Mila1
        Hi! I wanted to upgrade a few low-power HP mini from a Pentium Gold to i3-i5 processors.
        But, I noticed, that the motherboard or BIOS doesn't let it work on 35W, it caps CPU at around 20W, even if I put 65W i5 processor.
        Cooling is not a factor, even with normal CPU temperature, it doesn't go over 20W and has a mediocre performance.
        All power adapters are 65W+, I also tested with 120W adapter which works fine with a high power HP 800 G5 i5 that has a different heatsink and spins processor to 65-70W without any issues.
        I'm not looking for a 20W->65W jump, just would like...
        06-10-2025, 01:09 PM
        Allwinner H5 Quad-Core OTT Box Processor Datasheet
        The Allwinner H5 is a highly cost-efficient quad-core OTT Box processor, which is a part of growing home entertainment products that offer high-performance processing with a high degree of functional integration.
        The H5 processor has some very exciting features, for example:
        • CPU: Quad-core ARM CortexTM-A53 Processor, a power-efficient ARM v8 architecture, it has 64 and 32bit execution states for scalable high performance ,which includes a NEON multimedia processing engine.
        • Graphics: The hexa-core ARM Mali450 GPU including dual Geometry Processors(GP)...
        10-23-2024, 02:24 AM
      • ktmmotocross
        is |Intel BGA processors so CRAP?
        by ktmmotocross
        have in hands another intel CPU in Asus x555ld tat have 3.3VA rail shorted.
        inject 3.3V and PCH part start high heat.
        i cannot count how many times im see this on intel BGA CPUs
        is it really that crap CPUs?
        03-11-2020, 03:16 PM
