HP 800 mini G4, G5, G6 changing PL1, PL2 via BIOS or hardware
  • Mila1
    • Jun 2025
    • Netherlands
    Hi! I wanted to upgrade a few low-power HP mini from a Pentium Gold to i3-i5 processors.
    But, I noticed, that the motherboard or BIOS doesn't let it work on 35W, it caps CPU at around 20W, even if I put 65W i5 processor.
    Cooling is not a factor, even with normal CPU temperature, it doesn't go over 20W and has a mediocre performance.
    All power adapters are 65W+, I also tested with 120W adapter which works fine with a high power HP 800 G5 i5 that has a different heatsink and spins processor to 65-70W without any issues.
    I'm not looking for a 20W->65W jump, just would like to make sure T-series processors can give 100% at 35W.
    Is there a way to overcome this limitation by means of hardware or software changes?
    If so, please guide me. I have an EEPROM/FLASH programmer and a hot-air/rework station.
    Thanks, Mila.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12396
    Thanks, Mila.
    https://www.badcaps.net/forum/troubl...21#post1622421
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
    • macabook
      by macabook
      🧩 Initial Issue
      07-24-2025, 02:17 PM
    • pirati
      by pirati
      10-27-2025, 04:20 PM
      by Vesko356
      08-11-2023, 03:27 AM
    • limann
      Bios HP EliteDesk 800 G3 Mini 65W
      by limann
      I need Bios for HP EliteDesk 800 G3 Mini 65W, please support
      *Serial No : 8CG7427T48
      *MB Info : Scorpius MB Rev A
      16515-1
      348.06N35.0011
      *Proplem : No power on - 3 flashing red & 5 white, speaker : beep bep beep
      Thank you...
      10-02-2025, 07:53 PM
