LA-9591P Chip identification request
  • Mazorca
    • Jan 2017
    • 463
    Hi, I have a dell Ultrabook with an LA-9591P motherboard. This chip heats up rather quickly, cosuming more than 2 amps at 1.5 volts. It is marked with a slanted P then 7403 and underneath GA3131. On the schematic it is PQ700. I can't find the datasheet for it, any help?
    • 21874
    Re: LA-9591P Chip identification request
    i think its a vishay Si7403DN http://www.s-manuals.com/smd/74
    • Mazorca
      • Jan 2017
      • 463
      Re: LA-9591P Chip identification request (solved)
      Thank you SMDFlea, Mouser Electronics here in the USA doesn't carry it, I will continue looking now that I really know what it is. Can I substitute with another mosfet with same values ( 20V 4.5A 3.5W) in same package, trenchfet?
      Edit: I found this: Si7403BDN-T1 is the same part, and Mouse does carry it.
        • 21874
        According to this post on elvikom the PQ700 is a SQ7415EN ,its rated at 60V https://www.elvikom.pl/dell-7440-ply...je-t54449.html . I`m not sure what part you need now, can you take a close up photo of PQ700 ,and other members here might have some suggestions as to what the right part should be.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3627
          • slovakia
          just replace it with any p-channel 20A 30V mosfet
          • DynaxSC
            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
            by DynaxSC
            Hi
            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
            08-04-2025, 12:20 PM
          • e-repair
            Chip identification on hp omen 17cb1008tx
            by e-repair
            Hello !
            i have an to repair an hp omen 17cb1008tx.
            i have a short on a power supply chip, sempt powering the chipset. the chip was burned, but i can read the chip making code but i can't find any references. chip reading is AWSBVC. the chip have an output directly on a coil. sempt to have no damage on the rail behind but can't confirm.
            can you help me find a reference for this ic ?...
            09-23-2025, 03:38 AM
          • mizuh0
            MSI B660M Mortar DDR4 (MS-7D42 Rev 1.1) Request for EC flash chip (W25X20CLNIG)
            by mizuh0
            Hi all I hope im doing this correctly,
            I need a firmware dump for the Nuvoton NCT6687D‑M controller (EC flash chip: W25X20CLNIG) used on the MSI B660M Mortar DDR4 (MS‑7D42, revision 1.1).
            I acquired a ch341a black to reflash my bios, and was so excited to use it that I tested it on the W25X20CLNIG 3.3v chip as I didn't have the 1.8v yet for the bios chip itself.
            Being a total newbie I straight up corrupted the EC flash chip, and now the power button does nothing, PS_ON# does not change, and when I manually short the PS_ON# pin it immediately turns off...
            07-23-2025, 03:52 AM
          • Sunday1302
            Need help with GIGABYTE B550 UD AC REV 1.0 chip identification
            by Sunday1302
            I removed this chip with markings "14 8A SA4" between an HDMI port and a USB port that was faulty. I need to replace it, but I have not been able to properly identify this chip using the markings provided on the chip itself. If anyone is able to provide information regarding this chip, I would greatly appreciate it....
            10-26-2025, 02:35 PM
          • TamFishe
            ThinkPad X1C6 winbond 25q80dvsig chip dump request
            by TamFishe
            Hi, I got a ThinkPad x1 carbon 6th gen from a friend after in an attempt to fix it he ended up bricking the motherboard. today i tried plugging the laptop to the wall and i got no signs of life, despite the connections being proper. i've found out this winbond 25q80dvsig chip under a label near the usb c ports and i gave it a read, and the output has massive chunks of 0000 0000 0000 0000 followed by FFFF FFFF FFFF FFFF and sometimes some proper values scattered across the whole chip. I've attached the file because I've read people request it in order to fix it. Moderators, if I've posted this...
            08-22-2025, 02:20 AM
