I removed this chip with markings "14 8A SA4" between an HDMI port and a USB port that was faulty. I need to replace it, but I have not been able to properly identify this chip using the markings provided on the chip itself. If anyone is able to provide information regarding this chip, I would greatly appreciate it.
Need help with GIGABYTE B550 UD AC REV 1.0 chip identification
by DynaxSCHi
I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6... -
by dr.thodtOn a Gigabyte B660M DS3H AX I found a chip with a crater. I was not able to find a boardview/schematic of this board.
I have a hard time identifying it, so maybe you would be so kind to help me out.
It the first two symbols are most probably N3, followed by DPC.
Already thanks for your attention.1 Photo -
by e-repairHello !
i have an to repair an hp omen 17cb1008tx.
i have a short on a power supply chip, sempt powering the chipset. the chip was burned, but i can read the chip making code but i can't find any references. chip reading is AWSBVC. the chip have an output directly on a coil. sempt to have no damage on the rail behind but can't confirm.
can you help me find a reference for this ic ?...1 Photo -
by SMDFleaCommon SPI bios chip programming Questions and Answers
Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
A: If you can`t read from it how do you expect to write to it ?.
Q: Why is my bios chip unreadable ?.
A: The programmer is faulty or has a worn or broken zif socket.
The USB cable is frayed,connector pins worn or some other physical damage.
Not enough amperage or voltage to power the programmer properly.
Bad...-
Channel: BIOS Requests ONLY!
09-02-2021, 04:40 PM -
- Loading...
