Please Help Identify Missing BIOS Voltage
  • sparrow2719
    • Oct 2015
    • 69
    • Indonesia
    Hi I have an acer e5 471 with no voltage on bios, their vcc line pin 8 is missing 3.3V.
    Based on the block diagram i have, the voltage +3V_PCH_ME for bios voltage is coming from +3V_S5 (pic 3).
    +3V_S5 is coming from AO3404. A3404 is getting power from +3VPCU. (Pic 2).
    The one thing confused me is the PCH is also has a +3V_S5 and so on. (Pic 1).
    Is this PCH is distributing out the voltage too or it is an input voltage for PCH ?
  • khaahk
    • Dec 2013
    • 765
    • Estonia
    Re: Please Help Identify Missing BIOS Voltage
    You will get +3V_S5 (also on bios chip) when EC gives S5_ON control signal to AO3404. If you have high level on S5_ON then check the transistor, if not then check if EC has power.
    3V is input for PCH.
    Check PU3 output voltages 5v and 3v and 15v.
    • sparrow2719
      • Oct 2015
      • 69
      • Indonesia
      Noted, thanks for the info.
      It turns out the AO3404 bad, replaced and solved.
      Thank you.
      • Crypts
        • Feb 2023
        • 10
        • Algeria
        hello Friends..
        can you help me where i can find the circuit AO3404 in motherboard for testing and changed
        • Crypts
          • Feb 2023
          • 10
          • Algeria
          schematic board..
          https://www.badcaps.net/forum/troubl...ta-zaar-rev-3a
          • erico
            Lenovo X1 Carbon BIOS not getting voltage
            by erico
            First of all, ive veen reading these forums for some time and its always veen very helpful, so i thank you all for this amazing comunity.
            I have a lmq-2 13268-1 motherboard from a lenovo x1 carbon 3rd gen. And the MX25l12873f (U49) bios pin 8 is not getting voltage.
            So far these are my diagnostics:
            When given 19v trough power adapter, consumption reads 0.003 amps for about 5 seconds then nothing.
            When power button pressed same result, and i get three green blinking lights from the pwr btn led. But foesnt turn on.
            If i plug the battery...
            05-02-2024, 02:40 AM
          • Vesko356
            by Vesko356
            08-11-2023, 03:27 AM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • zenius
            by zenius
            12-08-2024, 06:13 AM
          • Wahaz
            by Wahaz
            10-30-2023, 08:42 PM
