HP Probook 440 G3 caps lock blinks 3 times
  • Dinneke
    • Apr 2014
    • 154
    • Netherlands
    DA0X61MB6G0 REV G UMA
    Just blinks 3 times once and and bit later on fan speeds up to max.
    I tried several BIOS dumps from this forum with no luck.
    Please some help.
  • pecrie
    • Nov 2011
    • 182
    Re: HP Probook 440 G3 caps lock blinks 3 times
    As far as I know with HP - 3 blinks of Caps lock light , means a problem with the internal RAM memory.
    Take out the memory modules and put them back in.
    Or leave them out and see if ti makes a difference.You will have 3 blinks when there is no memory installed -
    • Dinneke
      • Apr 2014
      • 154
      • Netherlands
      Thanks for your input!
      RAM replace/reseat etc makes does not do the trick
      • mielta
        • Apr 2015
        • 368
        Hi
        Messure if Rampower is OK
        It must be 1.5Volt
        • Dinneke
          • Apr 2014
          • 154
          • Netherlands
          It is 1,35V (DDR3L)
          • pecrie
            • Nov 2011
            • 182
            Voltage for these RAM must be 1.35 V ??You have measured that with a multimeter ?
            Are these the correct memory modules for this laptop model ??Are you sure about that ?
            If all the modules are out , do you still have 3 blinks ?
            And does the laptop wants to start ?? Is the fan spinning etc ?
            • pecrie
              • Nov 2011
              • 182
              Just want to add :
              Take out all the RAM and measure the voltage again.
              Is it still 1.35 Volts ? Is there a difference in the value ?
              I'm not sure but I believe that you don't need to start up the laptop.
              Just connect the adapter - leave the battery out - do the measurement
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                DDR3-L is the correct memory module on this platform and it runs on 1.35V. So that's ok. Still sounds like a bios issue. Can you post your backup here??
                • Curtissimo
                  HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                  by Curtissimo
                  Hi everyone.
                  I have a HP Elitebook 850 G8.
                  Serial: 5CG2324XM0
                  ProdID 6L8D5EC#ABA
                  It has a Winbond W25Q256JVEN Chip.
                  I need to remove BIOS Password.
                  I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                  Attached my dump.
                  I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                  I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                  What I did:...
                  08-26-2025, 04:42 AM
                • esqmooo
                  HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
                  by esqmooo
                  Hello everyone.
                  This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
                  Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
                  Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
                  I tried long pressing on the power button, after several seconds it would go off then when the button is released...
                  03-11-2025, 03:57 PM
                • esqmooo
                  HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
                  by esqmooo
                  I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
                  03-07-2025, 05:55 AM
                • zlr8r
                  HP Probook 640 G5 - replaced blown components, getting power led, fan full, 5-flashes on CAPS Lock and NUM lock, black screen
                  by zlr8r
                  Hey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
                  To begin with, this laptop was dead-dead.
                  Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;
                  • am getting white power led
                  • 5-long-flashes on CAPS Lock and NUM lock
                  • then, fan full speed
                  • CPU heats up some (smaller die PCH, does not)
                  • always constant black screen no matter what's tried
                  • no USB recognition
                  • no HDMI output
                  this is as far as I can get with it and not sure where to inspect next ?
                  I tried...
                  03-27-2024, 03:13 PM
                • someonenotyou
                  HP ProBook 445 G7 no POST only on battery
                  by someonenotyou
                  Hi.
                  I have a strange problem with HP ProBook 445 G7 (DA0X9MMB8F0 RevF), that there is no POST while only on battery. The Caps Lock blinks 5 times slowly.
                  When I attach DC Jack, the laptop will charge the battery and switch on.
                  And now the strange part:
                  1. While the Windows is still loading, and I will remove the DC Jack, the screen goes blank and the Caps Lock light will start blinking 5 times slowly.
                  2. When Windows has been loaded and on desktop, when I unplug DC Jack, it will work normally on battery. While still on battery mode I switch the laptop...
                  06-30-2025, 01:24 AM
