Q5WV1 LA-9712P rev2.0 Power On bt Black Screen
  • pratyush
    • Sep 2018
    • 69
    • India
    No any voltage on PL22 +VGFX_CORE is 0
    IMM_DRAMRST (pin30 ram slot)- 1.3V
    Flashed EC bios
    Plt_rst coming
    Nd at U35 sytem power is ok.
    what should I do?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Q5WV1 LA-9712P rev2.0 Power On bt Black Screen
    Do you mean LA-7912P?? Main bios not flashed?? What about Vcore ic?? can be PCH issue also.
    • pratyush
      • Sep 2018
      • 69
      • India
      sorry it is LA-7912p.
      Only I flashed EC bios...
      Vcore IC PU13...
      UGATE1G ND PHASE1G pin31 nd32 not coming...so +vgfx_core is also not present at PL22
      • pratyush
        • Sep 2018
        • 69
        • India
        Vcore voltage is present
        • mahmoodjavan
          Banned
          • Mar 2018
          • 584
          • iran
          Vcore IC PU13...
          bios and EC
          • piernov
            • Jan 2016
            • 4435
            • France
            Flash main BIOS with a known good one (backup the old first as always).
            • pratyush
              • Sep 2018
              • 69
              • India
              Flashed main bios but condition is same
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                La-6901P/7912P/Dell N5050-missing GFX core is mostly due to PCH.So if you have tested it with good ram stick, main bios, Vcore IC and then likely PCH issue. If you have Bga rework station, then try changing PCH(Reballing will not do)
                • pratyush
                  • Sep 2018
                  • 69
                  • India
                  Thnx for all yr help.
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • reformatt
                    by reformatt
                    07-31-2025, 08:37 PM
                  • smic717394
                    by smic717394
                    07-25-2024, 10:16 AM
                  • Chrissygizmo
                    by Chrissygizmo
                    02-10-2025, 12:33 AM
                  • spice_disc
                    Vizio TV M50-C1 reboot cycle and static on screen
                    by spice_disc
                    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                    09-08-2024, 02:37 PM
