ACER TIMELINEX 5830TG no led no power alw present
    • 21932
    Re: ACER TIMELINEX 5830TG no led no power alw present
    6V at pin 15 if i`m reading the BQ datasheet correctly , on page 8 .
    • aniki4177
      • Nov 2018
      • 14
      • italy
      ok thank you i read it, i'm beginner in mb repair and i dont know if it must be present in all power condition. I assume that it will be always present.
      Is the same thing if I remove pl2 instead of pr28 (only for comodity)?
      • aniki4177
        • Nov 2018
        • 14
        • italy
        Hi to all,
        I had removed PR28 and test with PSU+BATTERY.
        In attachment the result.
        • aniki4177
          • Nov 2018
          • 14
          • italy
          Originally posted by aniki4177
          Hi to all,
          ADD
          -PSU ONly
          -BATT only
          -power connector
          -protection circuit
          I had checked every pin of BQ2472:
          -pin 7 according to datasheet "IOUT voltage is 20 timesthe differential
          voltage across sense resistor"
          maybe is too low?It also connected to protection circuit.
          • aniki4177
            • Nov 2018
            • 14
            • italy
            Is normal that the ENE-KB930 is hot with only power adapter plugged?
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              #26
              No shoul'nt be hot.
