Asus Rog G551JM not charging and A5 VNE / A5 GND
  • Kiop
    • Nov 2018
    • 28
    • France
    Hello
    So i had a bad motherboard with a bad A5 VNE dosen't power UP without a battery so i change it but made a mistake and remove one of two good wich was good i know ...
    So i changed it with a A5 GND but the battery dosen't charge so i thought may be it was the ic charger but coudnl't understand if it was the case or not i noticed there was big large track from the ic charger to the battery wich seems odd so i guess may be it really needs a A5 VNE .
    I noticed on a good mobo for the Asus N551JM that on the A5 VNE on the gate i got 23,4 volts but not on the A5 GND just 19 volts .
    So it was strange the two A5 VNE are the first step of the power supply .
    I checked also and A5 VNE and A5 GND should be compatible and intercheangable .
    Finally i took 2 mosfet from a Asus X555LD and it works fine now laptop are charging the battery .
    But why the A5 VNE and the A5 GND are different ?
    Any idea ?
  • Kiop
    • Nov 2018
    • 28
    • France
    Re: Asus Rog G551JM not charging and A5 VNE / A5 GND
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Both are N channel 30V,48A mosfets-so are same and replaceable. Earler fets or one of them might be defective.
      • Kiop
        • Nov 2018
        • 28
        • France
        Yes it should but no , i tried with 4 of them i ended taking a A5 VNE from a working mobo and changed the first one i mean the top one by that A5 VNE and now everything is working fine and all the tensions are there battery charging , mobo working fine ...
        And i don't understand why i got 23,4 volts on the gate of that mosfet , where is coming from , from the mosfet or the mobo ?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Getting 23v at pin4(Gate) is normal as its a N channel mosfet. For any N channel mosfet , gate voltage is 19V+6v approx. For P channel , The gate voltage is lower then 19v(Usually 6-12V). So its fine. The gate is controlled by your charging IC.
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3628
            • slovakia
            gate is driven by buck circuit that boost base to 24V
            • P1nkSl1p
              • Jul 2020
              • Belize
              Hi I have the same issue with a gl551jw and really want to know what the code on the mosfet you used is. I tested it and I get no voltage out of it. Just want to know what the code is to see if I can buy new ones. Also are the both chips the same? Because the bad one has no codes on it and I wasn't sure if they were.
              • Manuelh
                • Aug 2021
                • 4
                • South Africa
                Is this thread. Still active ?
                I am looking for the board schematics for this laptop .
                Running into the same charging issue
                  • 22027
                  Schematic requests go here -> https://www.badcaps.net/forum/forumdisplay.php?f=41
                  Use the forum search, it might be posted already.If not,start a new thread in the schematic requests section .
                  • Manuelh
                    • Aug 2021
                    • 4
                    • South Africa
                    Requested the schematic
                    Strange how we are all experiencing the same issue with this mainboard
                    • flat-earther
                      ASUS X54H laptop thinks it's always charging even with charger unplugged
                      by flat-earther
                      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                      Windows also shows ''Plugged in'' when charger is not connected.
                      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                      If I let battery run out and say it has 3% Windows will...
                      06-24-2025, 09:32 AM
                    • johnbeton
                      Asus X415EA not charging battery
                      by johnbeton
                      I have an Asus X415EA board that is not charging the battery after some liquid damage. Everything else works, except charging the battery.
                      So far I measured all the pins on the bq24780s controller with the following result:
                      1. ACN = 0.0V
                      2. ACP = 19.02V
                      3. CMSRC = 18.5V
                      4. ACDRV = 23.9V
                      5. ACOK = 5.9V
                      6. ACDET = 2.57V
                      7. IADP = 0.17V
                      8. IDCHG = 0V
                      9. PMON = ?
                      10. PROCHOT = 5.05V
                      11. SDA = 3.3V
                      12. SCL = 3.3V
                      13. CMPIN = 0.47V
                      14. CMPOUT = 6.0V
                      15. BATPRES = 0.0V
                      16....
                      05-19-2025, 04:05 AM
                    • coasterghost
                      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                      by coasterghost
                      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                      System Hardware:
                      Processor: AMD Ryzen 7 PRO 5850U
                      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                      09-08-2025, 10:46 PM
                    • lazenes
                      ASUS TUF Dash Motherboard FX516 REV 6.0 Model Device Not Charging
                      by lazenes
                      The device is not charging with the 19V 180W DC charger. If the battery is full, the laptop powers on normally. I can charge it via USB Type-C, but it’s very slow. I checked the schematics but couldn’t find a solution. I even replaced the BQ24800 battery charging IC, but the issue remains the same. I suspect a MOSFET or a fuse that I might be overlooking is preventing it from charging with the adapter. Has anyone experienced a similar fault before or has any advice?...
                      09-18-2025, 01:48 PM
                    • thomasmagic
                      not charging asus g531gw 1.6
                      by thomasmagic
                      hello,
                      if you can help me, i have mainboard asus g531gw Rev 1.6 with short and no power
                      i have found short on C3907 (PVDD_AMP) and remove it
                      Actually machine works but battery is not charging. I have test with new one and i have too replace BQ24780S (charging IC) and same problem.
                      It's not 1st time when i remove short after the battery is not detect
                      On mybook i know we can make jumper beetween two lines for recognised this one
                      do you have solution for pc and actually this mainboard? Thanks for your help ...
                      06-19-2025, 12:54 PM
