MacBook pro 820-315 CPU Vcore, no shime no picture, no brain. Help Guys.
  • nerkkka
    • Jun 2018
    • 12
    Hi. All the time I found answers in the google, but this time I can't find anything. I have macbook pro logic board 820-3115-b. The problem with this board is: Fan spin in full speed, no image no chime. Have troubleshooted all rails is pressend except no voltage on PPVCORE_S0_AXG_R. Have replaced U7400 three times plus mosfet at the same time, replased SMC. No idea what can be wrong with this board.
    U7400
    Pin 13; 1.42V
    Pin 45; 5.04V
    Pin 4; 0.05V
    Pin 24; 3.3V
    pin 12; CPUIMVP_AXG_PGOOD voltage 0.19V,
    pin 13; CPUIMVP_AXG_PWM2 0.72V,
    pin 24; CPUIMVP_PGOOD 3.3V.
    Pin 47; 3.3V
    Pins ;21;23;22; 1.05V,
    Pin 39; 4.3V;
    Pin 40; 4.45V;
    Pin 38; 0.0V;
    Pin 35; 2.05V;
    Pin 36; 1.94V
    Pin 8; 0.0V
    Pin 6; 1.12V
    Pin 10; 9; 0.0V
    Pin 11; 5.04V
    Pin 18; 15; 16 0.0V
    Pin 14; 4.78V
    Pin 31; 4.58V
    Pin 33; 1.11V
    Pin 32; 1.54V
    Pin 34; 6.16V
    Pin 44; 1.12V
    Pin 3; 1.12V
    Pin 43; 1.12V
    Pin 41; 1.12V
    Pin 42; 1.12V
    Pin 28; 4.57V
    Pin 26; 1.11V
    Pin 27; 1.53V
    Pin 25; 6.15V
    Pin 48; 0.57V
    Pin 1; 0.47V
    Pins 19; 29; 5.09V
    Pin 46; 5.04V
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: MacBook pro 820-315 CPU Vcore, no shime no picture, no brain. Help Guys.
    Try PRAM reset.
    Check CPU_RESET_L.
    Try to flash the BIOS. (save the old one) Or try with a BIOS chip from another board.
    • nerkkka
      • Jun 2018
      • 12
      Hi. Thanks for a fast replay.
      I have tried bios chip from another board, also tied reset SMC and PRAM. CPU_RESET_L is present 1.05V.
      What else can be wrong with this board? If dead CPU then will put them to spares.
      • piernov
        • Jan 2016
        • 4437
        • France
        Yeah no way to know what's going on at this point. Not really worth putting more time into it.
        History of the board? Liquid damage, drop, overheating…? Try to go over the whole board to spot any liquid/corrosion/knocked off component.
        You could check activity on BIOS and communication between SMC and PCH on LPC bus. But it's often useless.
        • nerkkka
          • Jun 2018
          • 12
          What you know about PPVCORE_S0_AXG? Because it is missed. Have checked on working board and there was around 0.5V. I have few boards with the same issue, that's way I would like to figure out and fix these boards.
          • piernov
            • Jan 2016
            • 4437
            • France
            PPVCORE_S0_AXG won't be present if the BIOS doesn't run or fail POST early.
            Most likely missing without display connected too.
            Also not beeping without RAM?
            • nerkkka
              • Jun 2018
              • 12
              No any beep, just starts and runs. I don't have a lot of experience with CPU vcores. If all rails are working, then I thing dead CPU. What resistance should be on CPU vcore and on the AXG?
              • piernov
                • Jan 2016
                • 4437
                • France
                Dunno on AXG, but doesn't really matter here, apparently doesn't even start the POST procedure as there is no beep without RAM. On VCore the resistance may be between a couple of ohms and 10 ohms or so, depending on the CPU (and temperature, and if it's in a good mood). i7 may have a lower resistance than i5, not a general rule though. Sometimes a high end i7 will have a resistance lower than 2 ohms.
                First culprit is still BIOS here. Then could be SMC, PCH, CPU, missing resistor… no way to know except replacing them or going all over the board to find something visually wrong.
                With an oscilloscope you could probe 25Mhz PCH clock, SPI ROM CS# and SMC LPC bus LFRAME#.
                • nerkkka
                  • Jun 2018
                  • 12
                  Thanks for your big help. I will try what you have said, if can't fix this boards then I have more boards for spares
                  • nerkkka
                    • Jun 2018
                    • 12
                    Hello everyone.
                    Who are good skills to fix macbook pro 13" 820-3115?
                    In last few weeks got few macbook with the same problem, they don't have brain.
                    Some one can explain going communication between PCH-CPU-SMC-BIOS.
                    I'm not good enough with CPU.
                    I hope so some master takes time to explain detailed how it's working.
                    Watched Louis on youtube, but hes just showing how to fixing and no detailed explanation.
                    If some one makes good post it will hell for a lot people.
                    Thank YOU
                    • envym
                      by envym
                      Hi everyone!
                      06-27-2025, 08:54 AM
                    • platinumsteel
                      Macbook Pro 2012 CPU Vcore Present No Post
                      by platinumsteel
                      Hi guys hoping you can help me solve this issue. I have 3x 820-3115 boards. One fully working with CPU Vcore 0.8v and posting which am using to compare against the other 2...The other 2 has CPU Vcore stuck at 1.12v and doesn't drop down to 0.8v.
                      PPBUS_G3H is 8.56v and all other rails present. They both do not post or give picture and no caps lock. Hoping anyone may have experience with this and advise me on a few things to try. So far the only thing i tried was a few different bios for this board and nothing changed same behavior persists I have the original backups saved.Thx...
                      01-08-2025, 04:18 PM
                    • Flasman90
                      Macbook Pro DFU Restore Issues
                      by Flasman90
                      I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                      - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                      - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                      08-30-2025, 10:27 AM
                    • tobeend
                      Bypass mdm macbook m2 ventura
                      by tobeend
                      1. RESET MACOS WITH IPSW
                      a. Power off MacBook, press and hold the power button to enter Recovery
                      b. Open Disk Utility, remove Macintosh HD
                      c. Reboot, connect to the network to Activate Mac.
                      d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                      d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                      e. Release the other keys, but keep holding the Power key for another 10 seconds
                      f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                      05-26-2023, 07:18 AM
                    • SarcasticOP
                      General question about MacBook power rails for repair.
                      by SarcasticOP
                      I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                      • PPBUS_G3H (12.6V-12.8V)
                        • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                      • PP3V42_G3H (3.42V)
                        • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                      • PPVRTC_G3H (3.3V)
                        • This
                      12-12-2024, 05:50 PM
