Hi i am kinda new to this but learning daily. I have a Lenovo B575 AMD processor that i am trying to load Windows 10 on. It posts fine and will load software but every time it needs to restart it has black screen but unit is running. If i hold power button to reset it starts up and runs fine until the next restart. Any help would be great
Lenovo B575 Black Screen
Tags: None
Re: Lenovo B575 Black Screen
Hi
If you have in the bios the option to disable wifi then try it or quit the card itself.
Know it's weird but hapends to mi once with an hp620 and Windows 10.
this notebook have a ralink 3090 wifi card
After the instalation is done enable or put back the wifi card.Last edited by danea; 09-28-2018, 04:57 PM.Comment
Hi thanks for the info. I tried but still the same. I reverted back to windows 7 install and no issues. Not sure what else to tryComment
Update the bios will solved the problem.The Night Drop Down, I Will Keep Try Until..., You Never know.
Dushi Kòrsou, Nos Tei.Comment
Ok thanks. I checked for this unit and Lenovo website does not have an update for this bios. Is there another update i can useComment
You can try windows 8 or 8.1 and cee what it does.The Night Drop Down, I Will Keep Try Until..., You Never know.
Yeah the unit will load W7 and 8.1 no problem but will not follow through W10 it will restart to black screen every timeComment
I think s an videocart issue, try to install the last update for the AMD Graphics card.The Night Drop Down, I Will Keep Try Until..., You Never know.
I have now been using laptop on windows 7 under all conditions like games,work ect and no issues. If i try to install windows 10 it will go to black screen on restart. Has anyone ever ran into this issueComment
Lenovo support has no drivers for win 10.try a clean install(not update),the in device manager right click each device and find the drivers using windows update.Comment
by VcemPzdHello everyone !
My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared
I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
I also had corrosion/oxidation on the... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by invertI want to fix a Lenovo Legion 5 15ACH6 laptop, the laptop turns on but the screen is black, GPU and CPU are cold.
Bios changed a few times, unfortunately it didn't help but it should have. Please help.
The hardware is AMD Ryzen 5 -
by master3112Hello everyone,
I have a Lenovo IdeaPad 5 15ALC05 NM-D701. When I press the power button, the fan comes on, the power button flashes but the screen remains black. The device has a current consumption of 0.7A. I only have a BoardWiever for the device and no schematic. I have already tried to rewrite the BIOS, but the behavior is the same.
I have checked all voltages and everything fits:
PU1901 LV5028RPC - works
PL6202 -5.08V
PL6201 - 3.32V
PL300 - 0.77V
PL2101- 1.8V
PL1901 - 0.77V
PL1902 - 1.8V
PL1903 - 1.21V
PL5601 - 1.10V... - Loading...
