How 350 g1 dead , when power button pressed, power and wifi light blinking continueosly but pc didn't power on . I have try hard reset no luck .need poo assistance plz
Up 350 g1 dead
by AndreasbestHello.
I received a bios locked 7410 with 25Q256JVEQ ,i dump the bios, unlocked it and flash it back, since then the laptop has no life signs at all except amber led on for as long the power button is pressed, nothing else.
Fact #1 i was unaware that 25Q256JVEQ is 3.3v and i used a 5v CH341A to program it, not sure if the chip got damaged but since then i can read it and write it normally, doesn't seem dead.
Fact #2 i modded the CH341A to 3.3v, same results with programming though, nothing changed.
Fact #3 i tried hard reset with cmos/main battery disconnected and power... -
by mecha1166I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
Hey there people
While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
This is what I tried, but not in any order.
Google
YouTube
BIOS
Command Prompt (administrator privileges)
On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...-
10-25-2025, 02:22 AM -
My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
During these seconds the function button is not working...2 Photos-
by pc_okayHello friends,
I have this laptop AMD Platform starting & not posting, fan spinning.
When i press power button, the board get almost immediatly 0.5A ~ and board get stuck at 0.5A with power button led blinking indefinitly.
If i stop the computer (pressing 5s power button), board stop and when i restart i get approx 0.37A ~ and
I try to reflash the bios with no luck, same result, and i try disabling onboard ram (i remove resistors accordling schematic), no more progress.
CPU and his area heat, maybe the cpu is dead?
... - Loading...
