Dell Inspiron 3458 - Battery won't charge
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Machine came with power fault i.e. powering on with battery but no power with adapter. Found PU4401 and PR4421 were the problem. Now machine shows plugged in and charging, actually it is not charging battery. BAT+ have no charging voltage, if I take out battery it has 2.5v
    any ideas people.
    Thanks in advance.
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Re: Dell Inspiron 3458 - Battery won't charge
    somebody
    • danielsak
      Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
      by danielsak
      Hello, I have issue with Dell Inspiron 3542.
      Motherboard marking:
      Code:
      PWB FX3MC REV: A00
      The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
      1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
      1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
      10-11-2024, 04:36 PM
    • madjid911
      Dell Inspiron 15-3511 NO charge battery
      by madjid911
      Hi, Can you help me on the LAPTAOP Dell Inspiron 15-3511 with motherboard GDM50-LA-L241p, it lights up very well with charger but does not charge the battery, the charging light flashes orange, if you put a new battery the pc turns on, but even with a new battery the pc does not charge the battery.
      I'm not very good at schematics, but I believe that pub01 has a problem, it does not deliver a strong enough voltage on the gate (UG1_CHG: 6v) of the mosfet PQ026
      I did not find any shorts or resistance dead, the ISL95869HRTZ is well powered at 19v.
      Do you...
      09-10-2023, 07:54 AM
    • ipatch
      dell inspiron 5567 laptop battery lipo WDX0R
      by ipatch
      recently i was gifted a dell inspiron 5567 for wiping the data on the hard drive. (yay me). however i already have a computer that i use, so i have no need for this computer. this computer wasn't without its problems though.
      1. i had to purchase an adapter to retrofit my older style dell laptop battery cable. (not too expensive) ~= 10 bucks for a 2 pack via amz.
      2. after that i had to find a spare cr2032 (easily found in my parts bin) and assemble a makeshift cmos battery thanks to some copper foil tape and some heat shrink tubing.
      got the computer...
      04-02-2023, 04:45 PM
    • HTR-Informatique
      by HTR-Informatique
      02-09-2025, 06:51 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
