samsung R428 no power
  • rickybucalan
    • May 2013
    • 322
    • philippines
    hello every one. i just wanna ask for help. i got samsung r428
    model: suzhou-UL-DDR3
    BA41-01214A
    Can't power on.
    checked : 19v line is ok
    there is no 5v & 3.3v on coil
    and i notice TPS51125 for 5v & 3.3v supply is getting hot.
    i already tried to replaced it but no luck it was same
    could anyone help me to find out what was the problem.
    thanks.
    tps 51125 checked Pin output voltage
    pin 16 VIN 19V
    Pin 13 ENO 4.8v
    pin 17 VREG5 3.9v
    pin 3 VREF 2v
  • RethoricalCheese
    • Mar 2013
    • 1518
    • Estonia
    Re: samsung R428 no power
    Check for short on +3.3V ALW.
    • rickybucalan
      • May 2013
      • 322
      • philippines
      Originally posted by the_boss
      check for short on +3.3v alw.
      there is no short at 3.3v line
      • mielta
        • Apr 2015
        • 368
        Hi
        Check Pin8 Vreg3
        • mielta
          • Apr 2015
          • 368
          this goes to KBC Controller U516 Pin14,39 and some other
          check for short
          • rickybucalan
            • May 2013
            • 322
            • philippines
            Originally posted by mielta
            hi
            check pin8 vreg3
            pin 8 2.2v
            • rickybucalan
              • May 2013
              • 322
              • philippines
              this goes to kbc controller u516 pin14,39 and some other
              check for short
              there is no short in
              pin 14 , 39, 40 ,119, 106, 84, 58, 68, 49.
              • rickybucalan
                • May 2013
                • 322
                • philippines
                and i noticed tps51125 chip gets hot. i dont know what was wrong
                • caspian
                  • Oct 2015
                  • 1589
                  • Laptop
                  here is the schematics:
                  https://www.badcaps.net/forum/attach...5&d=1500837159
                  how much resistance is at Pin8 and Pin17 and L6 and L7 relative to ground? the value of resistance is important.
                  • rickybucalan
                    • May 2013
                    • 322
                    • philippines
                    i got
                    04.15k ohm pin 8
                    083.0k ohm pin17
                    1.880k ohm L6
                    15.70k ohm L7
                    • caspian
                      • Oct 2015
                      • 1589
                      • Laptop
                      how much voltage is at pin1 and pin6 of tps51125?
                      • rickybucalan
                        • May 2013
                        • 322
                        • philippines
                        no voltage at pin 1 and 6
                        • caspian
                          • Oct 2015
                          • 1589
                          • Laptop
                          considering all the symptoms, it seems tps51125 is faulty itself. but I am not sure. if tps51125 is available from scrap boards, replace it again.
                          • rickybucalan
                            • May 2013
                            • 322
                            • philippines
                            i just did but it still same.
                            • piernov
                              • Jan 2016
                              • 4435
                              • France
                              Voltage and resistance to ground on PRTC_BAT?
                              • NIKHILKYOHANNAN
                                • Mar 2015
                                • 6
                                • india
                                check the impedance of smd capacitors around ICH(U517) and SIO(U516).
                                Once i got the same problem,that time my SIO was faulty. Replaced SIO. it got ready.
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  I'll suggest to remove kbc, clean the pads on mb and connect ac adapter and check tps51125 is getting hot or not.
                                  • dj_ricoh
                                    • 2073
                                    If that tps gets hot then there is something shorted to ground.
                                    If kbc it's shorted then you can't power if you lift it right?
                                    There need to be an output that tps it's giving that is shorted.
                                    • PantherDave
                                      by PantherDave
                                      Hi all!
                                      05-29-2024, 02:01 PM
                                    • GLISIT
                                      by GLISIT
                                      01-16-2025, 02:29 PM
                                    • mrtek
                                      Samsung UN43NU6950FXZA No power
                                      by mrtek
                                      Hi
                                      Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                      Main fuse = OK
                                      Back light LED = OK. Power them with aux power source
                                      LED output = OK 156V
                                      I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                      Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                      07-20-2025, 08:06 PM
                                    • hill01
                                      Samsung UE75MU7009TXZG Endless Power Cycle
                                      by hill01
                                      Hi everyone and thanks in advance for any help I might get here
                                      My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                                      About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                                      Since a few days, the TV won't turn...
                                      11-17-2021, 02:52 PM
