ipad 2 cannot restore suddenly restarting
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I have this ipad 2 which i cannot restore using itunes it gives always error 21 and then restarting and back to dfu mode.anyone can help on this please
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: ipad 2 cannot restore suddenly restarting
    have you tried 3u tools and ran update through it
    • String2016
      • Nov 2015
      • 2238
      • philippines
      already tried 3u tools the same issue i think this is a hardware problem
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        i have read a few threads and possible nand issue seems quite common too
        • GeirAndersen
          iPad .pcb file collection
          by GeirAndersen
          I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
          Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
          IPAD COLLECTION 1
          +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
          +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
          +---iPad mini3 820-00008(A1599) 820-00002(A1600)
          +---iPad mini4 820-00180(A1538) 820-00177(A1550)
          +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
          +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
          12-09-2024, 09:28 AM
        • grimacelord
          Apple iPad Pro 3rd Generation 12.9" (A1876) No Power/Charge When Screen Is Connected
          by grimacelord
          Hello.
          Working on an Apple iPad Pro 3rd Generation 12.9" that has a weird issue. When the display is NOT connected, the iPad will charge and power on normally. I know it's on because I can hear notification sounds and the charging notification sound.
          If I connect a brand new display to the logic board, the iPad will not turn on at all. When I connect the iPad to an 18W wall charger and a USB-C ammeter, I can see that the iPad is attempting to charge, but constantly "resets" after just a moment or two.
          For example, when I connect the iPad to...
          04-15-2022, 11:06 AM
        • ipatch
          ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
          by ipatch
          i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
          08-24-2024, 02:36 PM
        • Flasman90
          Macbook Pro DFU Restore Issues
          by Flasman90
          I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
          - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
          - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
          08-30-2025, 10:27 AM
        • iMuhtaseb
          820-02020 A2338 Restore/Revive Failed
          by iMuhtaseb
          A2338 - Pristine condition.. I took out of the board and inspected it.. nothing.. as if the computer is barely used even.
          Anyway, customer said they tried erasing/formatting it and it got stuck on Apple logo preventing to go further.. I asked them why they tried to erase it from the first place? They said it turned off randomly once.. then they erased it and it worked out for a few days then it shut off again..
          I put the computer in DFU; I downloaded the latest Ventura IPSW and restored it.. during the "Installing.." it restarts then it shows the exclamation...
          09-11-2023, 08:43 AM
