macbook air- 820-00165-A no PP5V S4RS3 or s4 state
  • gmorb
    • Sep 2017
    • 35
    as described i dont get either. i forced 5 volts onto pad 3 of dc in board connector and then hookup the charger i get 0.182amps wont turn on and i still get no s4 state.
    when i got this board j7000 was ripped out and i had to restore ppdcin_g3h to get to this point.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: macbook air- 820-00165-A no PP5V S4RS3 or s4 state
    Missing PM_SLP_S4_L then I guess. All other G3H/S5/SUS rails present? Green light on Magsafe? Any pulses on PM_SLP_S4_L or other S4/S3/S0 rails?
    • gmorb
      • Sep 2017
      • 35
      i do get a green light/g3h/s5/sus
      what i dont get is pm_slp_s4_L - no pulsing
      s4/s3/s0 rails get a little bit of juice about 0.050v
      one area of 3v3_s4 goes up to 0.460v
      • envym
        by envym
        Hi everyone!
        06-27-2025, 08:54 AM
      • Flasman90
        Macbook Pro DFU Restore Issues
        by Flasman90
        I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
        - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
        - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
        08-30-2025, 10:27 AM
      • tobeend
        Bypass mdm macbook m2 ventura
        by tobeend
        1. RESET MACOS WITH IPSW
        a. Power off MacBook, press and hold the power button to enter Recovery
        b. Open Disk Utility, remove Macintosh HD
        c. Reboot, connect to the network to Activate Mac.
        d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
        d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
        e. Release the other keys, but keep holding the Power key for another 10 seconds
        f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
        05-26-2023, 07:18 AM
      • SarcasticOP
        General question about MacBook power rails for repair.
        by SarcasticOP
        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
        • PPBUS_G3H (12.6V-12.8V)
          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
        • PP3V42_G3H (3.42V)
          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
        • PPVRTC_G3H (3.3V)
          • This
        12-12-2024, 05:50 PM
      • obelix24
        A2941 Macbook air 15” - 5V 0a
        by obelix24
        I’m working on one macbook air 15” m2 that was water damaged.
        keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
        i’ve put macbook in shelf and order new screen so i can fully repair it.
        Now i got the screen and macbook stays at 5v 0a.
        i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
        i don’t have schematics so i don’t know where to start can someone help me?...
        03-27-2025, 01:19 PM
