Any alternative 4455 mofsets? I can use
					4455 mofset alternative?
	Tags: None
 Re: 4455 mofset alternative?
 pu301
 Vcc dead 0
 Maybe causing 19v 0.0amps not drawing amps
 Can that be the causeLast edited by Stevie2001; 07-06-2018, 12:34 PM.Comment
 Pq302 and other one is fine i checked shematics one of the other parts that connect to b+ showing less then 19v and following that line ends up in that ic one of the pins
 Yes vcc pin 0Last edited by Stevie2001; 07-06-2018, 12:37 PM.Comment
			by pc_okayHello guys,
 I quadruple check my dc mofset and they are not leaking.
 But first one is giving me million and millions ohms in every ways (gate <> source <> drain <> gate) could it be this little b....?
 But I get not voltage after first mofset 0V, I get 0.95V after 2nd mofset.
 On my ic chip i get: (without battery)
 ACN 0.91
 ACP 0.91
 CMNSRC 0.38
 ACDRV 0.05
 ACOK 0
 ACDET 3.1
 IOUT 0
 SDA 0.1
 ILIM 0
 BATDRV 2.2
 SRN 0
 SRP 0
 GND 0
 LODRV 0
 RGN 5....
			by pc_okayHello friends,
 I replace a shorted mofset (PU8104), now laptop is starting but no display, stopping at DRAMRST#.
 Resistance to ground on PL8104 is around 1-2 ohm, quite low but voltage seems ok 0.995V
 Any help would be appreciated it's a nice laptop !
 Thanks. 😃
			by baxmaxHi, Recently my Samsung 4K QE55Q60AAUXXH just suddenly stopped working_ there is no any sign of life - no red light or anything..and think, after diagnostic, it is diode DM863c SF28e PK33 siyu or one of these four. Is there any alternative I can replace with since it is hard to find it in my country and to order outside is quite difficult. thank you...2 Photos
			by NorrecitoHi,
 A friend of mine gave me an iPod nano G3 to see if I can fix it for him.
 The device had a faulty battery and he tried to replace it but failed. In the process he managed to pull off the pads that corresponds to the white battery wire (marked with a red circle in the images)....from both sides of the PCB. Fortunetely he didn't damage anything else.
 This is usually an easy fix HOWEVER, on the PCB, I see no traces coming from the VIA and after searching the internet, I've found no schematics nor boardview for this device. With the pads gone from both sides I seem...2 Photos
 I can't find any shematic for this board and i have a mofset (i think) completly burn.
 I can't read the marking. :'(
 Can someone help me please with photos attached?
 Thanks !3 Photos
- Loading...
