HP 17-x057nf mofset completly burn no more marking
This topic has been answered.
  • pc_okay
    • May 2022
    • 241
    • FRANCE
    Hello guys,
    I can't find any shematic for this board and i have a mofset (i think) completly burn.
    I can't read the marking. :'(
    Can someone help me please with photos attached?
    Thanks !
  • Answer selected by pc_okay at 06-13-2024, 05:58 AM.
    Fraheeba
    • Dec 2018
    • 9
    Originally posted by hamzafox
    Try 7410 mosfet
    CAUTION, rather not, the originals are P-Channel MOSFETS 7403
    • hamzafox
      • Nov 2019
      • 81
      • SYRIA
      Try 7410 mosfet
      • pc_okay
        • May 2022
        • 241
        • FRANCE
        Thanks I'll test it.
        • Fraheeba
          • Dec 2018
          • 9
          Try 7410 mosfet
          • pc_okay
            • May 2022
            • 241
            • FRANCE
            Hello !
            Big thank you guys!
            The mofset burn because of a bad condo on the other side of the board.
            Now work like a cham with the new MOSFETS 7403!
            • ttmi100x
              HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
              by ttmi100x
              Greetings everyone,
              I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
              The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
              Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
              Upon closer inspection...
              07-31-2024, 06:36 PM
            • howardc64
              Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
              by howardc64
              Eventually discovered a burn mark near lower corner of LCD. Here is a summary
              • Backlight on, no image
              • Disconnect right buffer board (view from front), left side display comes on
              • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
              • Buffer board is pretty simple
              Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
              07-11-2025, 04:04 PM
            • pc_okay
              HP BOARD LA-H323P (Not mofset again ?!)
              by pc_okay
              Hello guys,
              I quadruple check my dc mofset and they are not leaking.
              But first one is giving me million and millions ohms in every ways (gate <> source <> drain <> gate) could it be this little b....?
              But I get not voltage after first mofset 0V, I get 0.95V after 2nd mofset.
              On my ic chip i get: (without battery)
              ACN 0.91
              ACP 0.91
              CMNSRC 0.38
              ACDRV 0.05
              ACOK 0
              ACDET 3.1
              IOUT 0
              SDA 0.1
              ILIM 0
              BATDRV 2.2
              SRN 0
              SRP 0
              GND 0
              LODRV 0
              RGN 5....
              10-08-2024, 08:57 AM
            • Seville
              Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply
              by Seville
              Hello all!
              Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply .
              I have a Westinghouse LED TV, model WD48FAB100 that is not powering on. Upon removing the back cover, I noticed a burn mark where the AC cord connects to the power supply/main board. In this model, there is only one board combining the two functions. Previous owner said the TV experienced a lightening strike, but who knows. I checked the main fuse, tested OK. Here are a collection of readings from the power supply ports. Looking for some guidance on what to test/check next....
              10-10-2022, 07:31 AM
            • Barttech Computers
              hi all need help with IC marking is XA2LD Sot-23-5
              by Barttech Computers
              I'm trying to identify a small SOT-package IC marked "XA2LD" located near the 5V_FS rail on a logic board. The silkscreen shows it as U26/U25, and it's adjacent to components labeled R415, C232, L28, etc.
              Here’s what I know so far:
              • The IC marking is XA2LD (possibly custom or abbreviated).
              • It’s likely involved in power switching or regulation (possibly a load switch or LDO).
              • The package appears to be SOT-23-5 or similar.
              07-27-2025, 09:27 PM
