Lenovo U330P backlight problem
  • Dr.xyz
    • 11
    • Finland
    Mobo Quanta LZ5. Screen backlight stays on at bios, but when booting to any operating system, when panel switches to higher resolution, backlight turns off.
    Still can see picture with flashlight and everything else works normally. Backlight voltage from mobo seems low, only ~8 volts. Is this correct?
    Laptop was worked on by another shop, they tested display panel in another computer and it was OK, so issue is with motherboard.
    Schematics from backlight voltage producing area would be nice...
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Lenovo U330P backlight problem
    Sounds like a driver issue. Did you try on a Linux LiveUSB operating system?
    • Dr.xyz
      • 11
      • Finland
      Yes, tried live linux. Backlight turns off soon after booting when resolution changes. Not a driver issue.
      • Dr.xyz
        • 11
        • Finland
        Lid switch is OK.
        When changing resolution from OS desktop, backlight briefly flashes once, but never stays on.
          • 20781
          Theres a schematic here on the other U330 thread https://www.badcaps.net/forum/showthread.php?t=70371
          • Dr.xyz
            • 11
            • Finland
            Yes, already have it.
            Removed Q1, no change. At least LCD_BK_OFF signal is not the cause. Will continue tomorrow with remaining PANEL_BKEN and DISPON signals.
            • eric35
              Problem backlight lenovo s145-15ast
              by eric35
              Hello ,
              I have Problem of backlight on my lenovo s145-15ast.
              I touched the lvds connector with the cable.
              it sparked and now my screen is very dark.
              I tested the f2 fuse and it seems good. it beeps with my multimeter in continuity mode.
              04-18-2023, 10:47 AM
            • s_specialist
              Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
              by s_specialist
              Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
              07-07-2025, 11:47 AM
            • perzyk23
              Lenovo T580 - LCD Panel problem - error 0288
              by perzyk23
              Good morning,
              I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
              10-25-2024, 12:42 AM
            • konradx
              Lenovo Thinkpad T15 Touchscreen problem bios
              by konradx
              i have problem witch Lenovo T15, my LCD display was demaged, i buyed New LCD, Touch screen version. Problem is LCD Working but Touchcreen not working, i wrinted to seller . He sended to me another LCD, but still not working. I have to Lenovo T480s with touchcreen LCD and that display and touch work. I think that is somethink like whitelist support LCD in BIOS. Someone have the same problem?
              That is my DUMP.
              My device:
              SN: PF29Y4N6
              1s20S7S2WF00PF29Y4N6
              MB: GT4A0 GT5A1 GP4A0 GP5A1 GT4A2 NM-C931 REV 1.0...
              09-06-2024, 01:33 AM
            • madrali
              lenovo e15 gen2 bios ? problem
              by madrali
              Model: Lenovo ThinkPad E15 Gen 2 (Intel)
              20TD-50S0KU00
              Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
              I used Lenovo's SmartBeep decoder and it returned error 0284:
              "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
              I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
              06-16-2025, 12:06 PM
