LENOVO U330 DA0LZ5MB8B0 Quanta LZ5 REV:D
  • kokono
    • Jun 2018
    • 203
    Hi all
    i have this board with strange problem
    when i received this laptop ,i found a bad capacitor , i removed it
    now, when power on motherboard, nothings
    i checked +PWR_SRC , about 0.7 volt
    when one side of PL6 ist float ,i measuring about 7 volt , this voltage ist normal ?
    any opinion ?
  • BlueMidnight
    • Jan 2015
    • 489
    Re: LENOVO U330 DA0LZ5MB8B0 Quanta LZ5 REV
    +PWR_SRC serve a dual purpose. It charges the battery, and it is also the main power rail for the rest of the board. But, everything connected to +PWR_SRC can run off of 7V just fine. I don't have one of those boards to compare it too, but that doesn't sound terrible.
    On a perfectly working board, the output of the charging buck regulator should be slightly higher than the battery voltage (probably up to ~8.4V). With no battery connected, it certainly might be configured to output just 7V.
    So, right now the problem just seems to be a short of some kind pulling down the rail voltage when PL6 is connected.
      • 21874
      Could you upload the schematic
      • kotnatan
        Banned
        • Apr 2014
        • 181
        • Ukraine
        http://**************/load/noutbuki/.../307-1-0-39765
        http://**************/load/noutbuki/.../307-1-0-39764
          • 21874
          Thanks for the links.I`ve tried to join remont-aud before but i can`t use the site with google translate.
          • BlueMidnight
            • Jan 2015
            • 489
            Schematic attached.. [MOD EDIT] link to schematic - https://www.badcaps.net/forum/troubl...ev-d-schematic
              • 21874
              Thanks for the schematic .
              • kokono
                • Jun 2018
                • 203
                thx for reply and sorry for my delay
                i tested all part and wont cant find any element that be short circuit
                • BlueMidnight
                  • Jan 2015
                  • 489
                  Something must be dragging down that power rail.
                  In situations similar to this, sometimes there is a shorted high side FET in one of the buck regulators (the FET connected between +PWR_SRC and the output power rail). These can be found with diode mode measurements across the FET.
                  It may also be useful to measure the voltage on all the coils. You may even find that ~0.7V getting onto one of them. Measuring resistance to ground on all the coils may provide clues as well.
                  You can inject a very small voltage onto +PWR_SRC using a bench power supply (if you have one). With enough current, the bad component may get hot. Or not. Depending.
                  And it's not easy on this particular board, but as a last resort you can desolder other components to isolate parts of the board (just like you desoldered PL6).
                  • kokono
                    • Jun 2018
                    • 203
                    i checked all mosfet in board and measure ohm model for short circuit.
                    all things is ok
                    • BlueMidnight
                      • Jan 2015
                      • 489
                      It's also possible for there to be a problem with PU7 or the surrounding components. For example, it may not be changing the duty cycle to compensate for loading on the output. It's easy enough to just measure all the pins of PU7 and look for anything strange. This should be done with PL6 connected.
                      • kokono
                        • Jun 2018
                        • 203
                        i changed PU7 and nothings
                        • kokono
                          • Jun 2018
                          • 203
                          and is it possible describe about ACDC_ID pin.
                          whats this ? how much voltage ?
                          • BlueMidnight
                            • Jan 2015
                            • 489
                            The actual voltage readings for all these checks you are doing are important. I can only help in the most vague terms without them.
                            The ACDC_ID signal identifies the wattage of the AC adapter to the motherboard. It is the center point of a voltage divider consisting of 2 resistors in series between 3.3V and ground.
                            The first resistor is 750 ohms and is connected between 3V and the ID pin. The second resistor is built into the AC adapter itself (in the plug) and connects the ID pin to ground.
                            Different wattage adapters have different resistors inside them. This creates different voltage levels on the ID pin. The voltage level identifies the wattage, and will obviously be somewhere between 0V-3V.
                            There will be no voltage on the ID pin if the 3V switching regulator on the board isn't powered up. And yours won't be since your main power rail isn't working.
                            • kokono
                              • Jun 2018
                              • 203
                              i removed PU6 , PU5 , PU1and PQ2
                              but dont change .i checked all PWR_SRC line ,all things ist ok and for sure i removed Pu6, pu5 pu1 pq2 . nothings
                              any opinion ?
                              • BlueMidnight
                                • Jan 2015
                                • 489
                                With PL6 connected, the AC adapter connected, and the battery disconnected, what are the voltages on all pins of PU7?
                                  • 21874
                                  Whats the voltage on PQ21 pin 5 ,have you tested PR102,PR106,PR107,PC96,PC97, and have you tried with the CMOS battery
                                  • kokono
                                    • Jun 2018
                                    • 203
                                    All pin in PU7 :
                                    1 >19.6v
                                    2 >19.6v
                                    3 >18.3v
                                    4 >20v
                                    5 >3.3v
                                    6 >2.6v
                                    7 >0
                                    8 >0
                                    9 >0
                                    11 >0.7v
                                    12 >0.8v
                                    13 >0.8v
                                    15 >0
                                    16 >6v
                                    17 >5.6v
                                    18 >0.8v
                                    19 >0.8v
                                    20 >19.4v
                                    • kokono
                                      • Jun 2018
                                      • 203
                                      PQ20 :G ,D ,S 20v
                                      PQ21 :G ,D ,S 20v
                                      in PU7
                                      ACN & ACP 19.6v
                                        • 21874
                                        What voltage are you getting on +3.3V_ALW2 ,and have you attatched the (good 3V) CMOS battery
                                          Lenovo E130 Quanta LI2 REVD,E,F Schematic & Board View
                                          Lenovo E130 Quanta LI2 REV D,E,F Schematic & Board View...
                                          10-02-2024, 02:10 PM
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                        • davidtgbe
                                          LENOVO U330 DA0LZ5MB8D0 Quanta LZ5 REV:D
                                          by davidtgbe
                                          Hi there,
                                          I have this laptop which is not powering on/charging with the AC adapter plugged in.
                                          At some point, battery ran out and the laptop did not charge anymore and did not turn on either.
                                          First things checked in the MB:
                                          - Visual inspection. All clean.
                                          - 19V on AC adapter -> OK.
                                          - PD11, PF2, PQ20, PQ21 -> OK (fuse, diode, mosfets)
                                          - C211 shows a short between GND and MX7 line to U20 (don’t know IT8587 internals, may be it is normal).
                                          - PC65 shows a short between GND and 3.3V_ALW2
                                          - Consumption 100mA @ 19V
                                          10-21-2022, 07:25 AM
                                          Lenovo 3000 Series Schematic
                                          Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                          3000 C100 laptop with Braille keyboard
                                          Lenovo 3000 C
                                          C100, C200 - 15-inch XGA screen
                                          Lenovo 3000 N
                                          N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                          N500 - 15.4 inch screen.
                                          Lenovo 3000 V
                                          V100, V200 - 12.1-inch WXGA models
                                          Lenovo 3000 G
                                          G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                          10-04-2024, 06:05 AM
                                          Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                          09-06-2024, 06:40 AM
