Lenovo U330P backlight problem
  • Dr.xyz
    • 11
    • Finland
    Mobo Quanta LZ5. Screen backlight stays on at bios, but when booting to any operating system, when panel switches to higher resolution, backlight turns off.
    Still can see picture with flashlight and everything else works normally. Backlight voltage from mobo seems low, only ~8 volts. Is this correct?
    Laptop was worked on by another shop, they tested display panel in another computer and it was OK, so issue is with motherboard.
    Schematics from backlight voltage producing area would be nice...
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Lenovo U330P backlight problem
    Sounds like a driver issue. Did you try on a Linux LiveUSB operating system?
    • Dr.xyz
      • 11
      • Finland
      Yes, tried live linux. Backlight turns off soon after booting when resolution changes. Not a driver issue.
      • Dr.xyz
        • 11
        • Finland
        Lid switch is OK.
        When changing resolution from OS desktop, backlight briefly flashes once, but never stays on.
          • 21849
          Theres a schematic here on the other U330 thread https://www.badcaps.net/forum/showthread.php?t=70371
          • Dr.xyz
            • 11
            • Finland
            Yes, already have it.
            Removed Q1, no change. At least LCD_BK_OFF signal is not the cause. Will continue tomorrow with remaining PANEL_BKEN and DISPON signals.
            • ravi_1617
              Lenovo B540 ,Starting Problem
              by ravi_1617
              Hello !
              Model Lenovo B540
              Board Details 09244-1
              LA14 DIS MB
              48.4DMO4.01.1
              This Board has starting problem , when CMOS batter is removed ,it starts (turn ON) by itself fine, than if is short power switch once board turns OFF Fine.
              when connected CMOS dont start.
              3.3 volts present at power switch (it slight less 3.267-87) .there was slight liquid spill at around U53 (SL62872HR),when I clean that area . I mean when its little hot board warm , board starts few time ON and OFF by power switch
              One more thing i want to mention ( by mistake i started at...
              10-14-2025, 02:08 AM
            • lucaszmn
              by lucaszmn
              Problem:
              Initial Findings:
              • I concluded that the
              08-12-2025, 03:01 PM
            • coasterghost
              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
              by coasterghost
              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
              System Hardware:
              Processor: AMD Ryzen 7 PRO 5850U
              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
              09-08-2025, 10:46 PM
            • eric35
              Problem backlight lenovo s145-15ast
              by eric35
              Hello ,
              I have Problem of backlight on my lenovo s145-15ast.
              I touched the lvds connector with the cable.
              it sparked and now my screen is very dark.
              I tested the f2 fuse and it seems good. it beeps with my multimeter in continuity mode.
              04-18-2023, 10:47 AM
            • s_specialist
              Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
              by s_specialist
              Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
              07-07-2025, 11:47 AM
