hp mini 210-1018cl 19v rail problem
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    I need help on this please hp mini 210-1018cl board idANM6AMB6F0 REV F: it came dead the problem is the 19v rail at first check pq32 pin has 19v but pin 2 0v and pin3 has 0.9v, so i replaced pq32 it works now there is a light and laptop can turn on and boots fine after a minute it goes dead again check again pq32 same as before no voltage on pin 2 and pin 3 has 0.9v so and check the fuse R030 markings has 0.9v so i replaced the fuse now 19v present and laptop can turn on and boots fine, but still same issue after a minute it goes dead again and no voltages on pq32 and the fuse R030.could anyone help on this please. if a put votages using bench lab on pq32 and R030 FUSE ligts present then goes off and taking 0.01miliamps on bench lab
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: hp mini 210-1018cl 19v rail problem
    In addition to pq32, you need to measure voltage on components which are connected to pq32. which IC does get hot?
    • Romulo
      • Nov 2016
      • 484
      • Philippines
      no any hot component connected to pq32
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Reflow the whole mobo at 200c
        • Romulo
          • Nov 2016
          • 484
          • Philippines
          if i reflow the motherboard it will reflow also the processor
          • caspian
            • Oct 2015
            • 1589
            • Laptop
            cover the processor using foil.
            • Romulo
              • Nov 2016
              • 484
              • Philippines
              i reflow the board using hot air still the same issue no 19v on pin 3 of pq32 and r030 has 0.
              9v.
              • Stevie2001
                • Apr 2018
                • 183
                • irland
                Download board view for your borad or buy one.
                Youtube mb boardview learn reflow on short makes no sense
                • Romulo
                  • Nov 2016
                  • 484
                  • Philippines
                  @steve2001 as ive said above I already done reflow the board it comes ok then a minute it goes back again to the same issue no 19v on pin 3 of pq32 and r030 fuse
                  • Stevie2001
                    • Apr 2018
                    • 183
                    • irland
                    change
                    PU2
                    ISL6251A
                    or
                    pu2 ic islxxxxx number
                      • 20659
                      Do you mean PR21 - RL3720WT-R030 which is a current sense resistor.
                        • 20659
                        There is no boardview available for this motherboard.
                          • 20659
                          Schematic for HP Mini 210 Quanta NM6 Annika .
                          • Romulo
                            • Nov 2016
                            • 484
                            • Philippines
                            thanks smdflea ill try to change the isl chip and see what happens
                            • Romulo
                              • Nov 2016
                              • 484
                              • Philippines
                              update: i change the chip isl 6251 now it's working does not go back to the issue but there is no display does anyone has a bios on this i will try to flash the bios the board idANM6AMB6F0 REV:F
                                • 20659
                                Check the LCD connector CN1, you should have 3V on pin1,2,3. And check voltage on pin 21 .
                                • Nagy Daniel
                                  Lowest possible resistance on laptop motherboard rail - Guide Table request
                                  by Nagy Daniel
                                  Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                  I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                  I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                  So, I generated a table with AI so I can...
                                  03-04-2025, 08:24 AM
                                • aldopc
                                  mini pc bios problem manufacturing unknown
                                  by aldopc
                                  Hi friends, could someone help me? I have a Chinese NUC with an apparent BIOS problem (no display). The problem is that I can't find the motherboard model anywhere, nor the model... that is, it's a generic mini PC but it doesn't have a model... I've read the BIOS file and I'm uploading it in case someone could repair it or someone who had one of the same... I'm uploading images of the motherboard and the PC......
                                  11-25-2024, 03:47 PM
                                  HP 260 G2 Desktop Mini PC i3-6100U Specification for Upgrade or Repair
                                  This specification for the HP 260 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC boardview and 260 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-12-2024, 03:36 PM
                                  HP Stolní počítač 260 G3 Mini i5-7200U Specification for Upgrade or Repair
                                  This specification for the HP Stolní počítač 260 G3 Mini can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Stolní počítač 260 G3 Mini boardview and Stolní počítač 260 G3 Mini schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                  09-12-2024, 02:20 PM
                                  09-12-2024, 02:15 PM
