Hi friends, could someone help me? I have a Chinese NUC with an apparent BIOS problem (no display). The problem is that I can't find the motherboard model anywhere, nor the model... that is, it's a generic mini PC but it doesn't have a model... I've read the BIOS file and I'm uploading it in case someone could repair it or someone who had one of the same... I'm uploading images of the motherboard and the PC...
mini pc bios problem manufacturing unknown
I'm not sure that information helps you but what I've found about that bios file:
Vendor BIOS Info :
- BIOS Vendor : AMI BIOS Aptio 5
- BIOS Core Version : 05.13.09.06
- BIOS Core Date : 14.09.2020 20:43:34
- BIOS Tag : GWHL3906
- OEM ID : ALASKAA M I
- Firmware ID : 91BCE0B6-DFAA-7904-0F4F-9A2ECCB1B952
Also this is (I believe) official website: https://minibox.cl. Unfortunately only spanish ? language, but you can try contact with them and ask for some information about your motherboard/bios.
Did you try clear ME Region ?
Thanks for the info, I have already contacted them, in fact this device was purchased there, it is from Chile (my country) and they don't even have the drivers on the page... much less the BIOS... I haven't tried to clean it... since generally the display failure is due to the BIOS region...Hi,
Vendor BIOS Info :
hi I'm going to describe what I do in these cases, when the support is very limited it requires you to re-match the parts of the machine such as video and USB ports number of memory slots PCIe ports ect. I look in the support of another company that has exactly the same MoBo configuration, I download that bios I verify that it is the same size example 8mb I write that directly to the tsop without editing anything I verify that it works, finally I update the same file again with some wizard or application that has the support to do this update type a .exe in Windows and voila.
tambien hablo español si quieres resolver alguna duda escribeme en el privado, suerteComment
I have same Chinese NUC. I was made a dump of my OK working BIOSHi friends, could someone help me? I have a Chinese NUC with an apparent BIOS problem (no display). The problem is that I can't find the motherboard model anywhere, nor the model... that is, it's a generic mini PC but it doesn't have a model... I've read the BIOS file and I'm uploading it in case someone could repair it or someone who had one of the same... I'm uploading images of the motherboard and the PC...
Use flash programmer and upload to your Winbond W25Q128*V
Or boot from UEFI Shell with AfuEfix64.efi and makeCode:AfuEfix64.efi dump.bin /p /b /n /capsule
Attached FilesPremium supporters get full download access and other benefits.
Chinese Vendor send to me new BIOS with flash utility to that Mini PC.
GWHL3906 -> GWHL3907Attached FilesPremium supporters get full download access and other benefits.
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
by traxformaniaHello,
I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
I'm trying to reset my bios without success.
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
Samsung NP900X3E BIOS problem – original BIOS freezes, another BIOS works but internal LCD corruptedby 5cszacsaHi,
I need help with a Samsung NP900X3E-K02HU BIOS.
S/N: JDML91GD500012K
Motherboard: AMOR2-13-MONO Rev 1.0 (photo attached)
After reinstalling Windows and rebooting, the BIOS stopped working properly. 1) With my original dump (corrupted)
File: samsung_np900x3e_kiolv.bin- On power on I only get a black screen / freeze
- I cannot enter BIOS Setup
- The laptop does not boot Windows
- (External HDMI output also does not help / still freezes)
File: samsung_np900 10 saniye.bin (att...-
by macabookHello everyone,
07-24-2025, 02:17 PM - Loading...
