Lenovo g500 switch on and off after 5 seconds
  • NConstantinou
    • May 2017
    • 351
    • Cyprus
    Testing the mono I found that I have short on +vcc_core, +1.05s_vccp and +vcc_gfxcore_axg
    I disconnected all positive side of 330u capacitors near CPU and I still have short.
    Does anyone has any idea!
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Lenovo g500 switch on and off after 5 seconds
    Exact resistance to ground on those? Higher than a couple of ohm is not a short on a CPU power rail.
    • NConstantinou
      • May 2017
      • 351
      • Cyprus
      I will test tomorrow and I will let you know.
      One more thing, under CPU there are 5_6 capacitors that are shown as short, and if CPU is install the PL905 is shown short to ground. If I remove CPU PL905 is not short that is the pl1 +vcc_gfxcore
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Cpu/gpu power rail always has very low resistance as piernov has said. I'll check first whether you have 5/3.3v VS voltage.
        • NConstantinou
          • May 2017
          • 351
          • Cyprus
          +vcc_core has 15ohms.
          I do have 3.3 and 5v VS
          • NConstantinou
            • May 2017
            • 351
            • Cyprus
            The resistance +vcc_core is 15ohms.
            • ibrahimtatli
              • Oct 2017
              • 6
              • uieuieu
              change the bios chip
              • tahc81
                • Nov 2019
                • 42
                • Slovakia
                15 ohms is acceptable for those rails. Let's imagine the startup sequence. EC (embedded controller) after power button press is checking the voltages, temperatures, maybe presence of some HW, buttons, lid... etc. If anything of these goes bad, EC will shutdown the laptop (mostly the VRM controllers generating all other voltages than 3V3 and 5V.
                In your case, it can be also SW issue, EC BIOS corruption, failed EC chip, or any other issue mentioned in a previous paragraph.
                • kotel studios
                  Lenovo B50-70 LA-B092P REV 2.0 - short on +3VLP
                  by kotel studios
                  My lenovo B50-70 laptop (mainboard compal LA-B092P VER 2.0) had a short on the +3V generation part (where PU401 is).
                  I've removed the SY8208BQNC and the short is gone on PL402. Although, it's still there on pin 5 "LDO" of the SY8208BQNC (1.8ohms to GND).
                  All other coils aren't shorted to GND.
                  Removing the PC412 cap didn't help. Mainboard pads are still shorted. Cap itself is fine.
                  Pin 20 (+3VLP) of ALC codec isn't shorted too, so it shouldn't be the issue.
                  Originally, the laptop wouldn't power on. It would get its 20V on the...
                  10-12-2025, 03:32 AM
                • SarcasticOP
                  Lenovo Legion 5 15ACH6H with possible short on +3VL.
                  by SarcasticOP
                  Hello!
                  I am working on a Lenovo Legion 5 15ACH6H that will not take power when connected to the charger and will not turn on. The device was left in a car overnight when it got cold outside and no longer powers on. Inside the device was relatively clean and dust-free, and it did not have any immediate signs of liquid damage.
                  The boardview files are available over at https://www.badcaps.net/forum/troubl...h-boot-problem. I am not sure of the etiquette...
                  01-13-2024, 09:44 AM
                • survivalbloke
                  Need help pinpointing my short on this board (Lenovo) NM-D351
                  by survivalbloke
                  This is a Lenovo Thinkpad P15s Gen 2 with a board NM-D351. I'm having trouble finding my dead short to ground. I have the area narrowed down after much probing. You'll see in the boardview, there are two coils involved. I removed those coils and verified that that short is not on the mosfet side of those coils. . You'll see an arrangement on both sides of the board of 5 caps and one smaller one to the side. I have removed ALL 12 of these small caps and still have the short. Prior to that I injected at those caps with 1v5a and the short was only drawing 800ma so I could not see anything on thermal....
                  03-23-2024, 11:24 AM
                • liquidzorch
                  Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
                  by liquidzorch
                  Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
                  10-18-2024, 05:19 PM
                  Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                  This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-06-2024, 05:30 AM
