need help quanta r33 rev 3.0
  • ggallarde
    • Jan 2017
    • 14
    • philippines
    on page 35 i got 19v on one side of pr116 but nothing on the other side..ive already changed it but same result..attached here was schematic..thank you in advance
    • 21913
    Re: need help quanta r33 rev 3.0
    Check PC75
    • ggallarde
      • Jan 2017
      • 14
      • philippines
      Originally posted by SMDFlea
      Check PC75
      thank you for quick reply..but i tested its not shorted
        • 21913
        It doesn`t have to be shorted, take it off and see if voltage comes up, if it does make sure to put a new cap on there ,don`t leave it off.
        • ggallarde
          • Jan 2017
          • 14
          • philippines
          i will try and post result..thanks again SMDFlea.
          • piernov
            • Jan 2016
            • 4439
            • France
            PU8 pin 16 (VIN) may be shorted to ground. Or there is a break in the line between PR116 and PU8. Or either PR116 or PU8 is not soldered properly. Also make sure PR116 is indeed 10 ohms.
            • ggallarde
              • Jan 2017
              • 14
              • philippines
              ive already change pr116 and still no 19v on the other side of it..pull-out pc75 still same result..ive notice that pu8 is getting hot..thanks by the way
              • piernov
                • Jan 2016
                • 4439
                • France
                PU8 shouldn't get really hot, try to replace it.
