please need help :crying:
  • amr soliman
    • Oct 2015
    • 145
    • egypt
    i haver acer 5733 (la6582p) it came to me with over heating
    i clean it change thermal paste change heatsink and fan but still shut down replacerd cpu capacitor and thermal ic still the same work without power press the same change processor and ram but still nothing change i/o nothing new install hard ware monitor cpu thermal betwin 45"/47" any one can help plz
  • melody4net
    • Dec 2014
    • 25
    • egypt
    Re: please need help
    flash 2 bios chip with this files
    • amr soliman
      • Oct 2015
      • 145
      • egypt
      i'll flash it an tell you result thank you
      • basic
        • Oct 2017
        • 229
        • 86357289244
        if doesnt work after flash let me know ,i had such a same almost same problem
        • amr soliman
          • Oct 2015
          • 145
          • egypt
          hi guys it doesn't work after flash still power down after 5 minutes
          • basic
            • Oct 2017
            • 229
            • 86357289244
            i had almost same problem in one Acer laptop
            i have try everything changed and same problem
            and the problem was on lcd cable which connect to board
            i have changed and fixed problem
            so my advice its worth try to change lcd cable
            • amr soliman
              • Oct 2015
              • 145
              • egypt
              i'm working with mainboard outside and connected to ext monitor without lcd cable
              • basic
                • Oct 2017
                • 229
                • 86357289244
                dissconect lcd cable from board and try in ext monitor and wait for more 5 mins and see what happens
                and let me know results
                • Stevie2001
                  • Apr 2018
                  • 183
                  • irland
                  Dc all wires only power wire lcd and usb all disconnect then power on and leave it if it last 10min then work your way in?
                  • amr soliman
                    • Oct 2015
                    • 145
                    • egypt
                    still nothing
                    • raajkumar
                      • Mar 2015
                      • 354
                      • Srilanka
                      I think have to rework on pch.
                      • amr soliman
                        • Oct 2015
                        • 145
                        • egypt
                        i did replaling to pch still nothing
                        • aanan
                          • Dec 2010
                          • 222
                          • India
                          CHECK capacitor C105 C272. 273. 275
                          • tomodachi
                            • Apr 2012
                            • 621
                            • Turkey
                            Ever tried to test it open cased with no cables attached ?
                            You can run a pcmark test that way and let us know
                            • amr soliman
                              • Oct 2015
                              • 145
                              • egypt
                              i'm already working just main board connected to ext screen
                              • amr soliman
                                • Oct 2015
                                • 145
                                • egypt
                                thx aanan but i replaced this caps but nothing happined
                                • nabilgo
                                  • May 2016
                                  • 312
                                  • L.A
                                  that is such a big problem i have 4 laptop with this problem
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    To me, it sound like me region issue. I have posted official bios for this model in this forum which you can find out by using "search". Give it a try and hopefully it might get resolved.
                                    • dg.ott.ca
                                      • May 2016
                                      • 5
                                      • canada
                                      I work in computer store, when people bring us acer for repair we always try to recycle them (as in; put them in garbage). I suggest you do the same.
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        I dont agree dear. I have repaired hundred's of acer and most of the times they are repairable.
