packardbell mz36 touchpad failing
  • danea
    • Apr 2013
    • 39
    • spain
    Hi everyone!have an packardbell mz36 and i was update windows 10 on it,version 1083.when finish and has to restart the touchpad start flickering and moving very fast on a small area without let me to do anything with it.
    i was use an usb mouse to restart the laptop and complete the update.when finish the touchpad is not working properly,sometime is not moving,sometime is moving very slow with a lot of sensitivity.
    Try:roll back windows 10,update bios,change cmos baterry,dissasembly an clean it,install windows 7 and vista,unninstall driver ,disable then enable,reset bios to factory settings,install synaptics driver....
    i can´t imagine how during an update it was happend someting like this.
    Any idea?
    Thanks.
    • 20318
    Re: packardbell mz36 touchpad failing
    Turn off any advanced touchpad gestures
    • danea
      • Apr 2013
      • 39
      • spain
      i arleady try that. also look for the irql to see if there is any confilict,disable fast startup feature of windows 10,press the power button for 30 seconds,try almost everything,my worse scenario is that it could be failing at hardware level.But still wonder how this coud be possible due to an update of windows 10.very frustrating indeed.one more thing,when i press the power button for a while the bios checksum shows a mouse initialized error message.
      Thanks.
        • 20318
        Check on the support/drivers website for a Synaptics firmware update
        • danea
          • Apr 2013
          • 39
          • spain
          install it.touchpad cursor not moving.
          • danea
            • Apr 2013
            • 39
            • spain
            done that already,not working.running out of options.guess i have to try another touchpad.
            Thanks.
              • 20318
              Have a look at the touchpad ribbon cable ,it might just need reseating, and check for corrosion/liquid damage. Oh, and i`m sure you`ve tried the FN key to enable/disable touchpad
              • danea
                • Apr 2013
                • 39
                • spain
                done that.no luck,guess i am dealing with a defective touchpad or motherboard.
                wonder if apci has something to do in this scenario.
                well,windows update was a bad idea in this case.
                Many thanks.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Boot from a Linux live disc to remove any doubt it being a driver issue.
                  • danea
                    • Apr 2013
                    • 39
                    • spain
                    i use hirens boot live cd but no change.same problem.
                    Thanks.
                    • B2L_Repairs
                      Macbook A1706 touchpad and keyboard not working. Please help
                      by B2L_Repairs
                      Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
                      10-09-2023, 04:56 AM
                    • claws77
                      lenovo flex5-14itl05, touchpad water damage
                      by claws77
                      last night i dropped some liquid over my laptop touchpad, immediately stopped using and tried to dry it up.
                      the touchpad misclicks, sometimes stops working altogether
                      i have removed the touchpad assembly cleaned it with alcohol and brush and cotton buds.
                      can i fully disassemble the touchpad assembly as i suspect some liquid is still lurking inside the trackpad.​...
                      07-15-2024, 07:34 PM
                    • MichelinMan
                      CF-20 Toughbook (mk1) Trackpad/Touchpad and USB ports not working
                      by MichelinMan
                      Hey guys,
                      Just purchased a CF-20 (mk1) supposedly was all working. However, the seller had done a fresh install of windows 10 but did not install any driver. Seller was adamant the trackpad/touchpad was working.
                      The touchpad/trackpad does not work. No led lights near the trackpad. The keyboard works, the USB 2 port on the base does not work, The USB 3 ports will recognise a USB 3 flashdrive but did not recognise a USB mouse. The ethernet port on the keyboard section works.
                      The USB 3 port on the actual tablet section works with no issues.
                      07-18-2023, 08:12 AM
                    • uintptr
                      Acer E1-571G Q5WVH LA-7912P Rev 1.0 Bypass Touchpad Requirement
                      by uintptr
                      Hello, i have Q5WVH LA-7912P Rev 1.0 motherboard on my old PC. I accidently broke the touchpad things when replacing the back and up case. After doing that my motherboard going to blinking orange light on LED2. When I properly seat that touchpad thing, it occasionally boots. I think the problem is because of this. I don't have a soldering iron, so I can't solder it there. Since I'm going to use the computer as a server, I don't need a touchpad. I'm also leaving a photo for better understanding. I need to short-circuit it and make it work all the time. Which pins is for short-circuit? Thank you....
                      01-02-2025, 09:36 AM
                    • jamesp
                      Asus TP412FA keyboard and touchpad not functioning
                      by jamesp
                      Hello guys,
                      need help, i have a laptop that i encountered having keyboard and touchpad not working, not immediately going to BIOS i already tried replacing even just the keyboard with a new one but still problem exists. now i only realized to checked it from bios to erase doubts. i found out both touchpad and keyboard are working only on BIOS but not on windows.
                      since i cant just reformat the said laptop, i tried installing MyAsus utility and updated my drivers , and windows update as well. i included updating the bios to latest 3.08 version. still kb and touchpad is working on bios...
                      08-18-2024, 11:02 AM
