HP 15-n027sa DA0U92MB6D0 not detecting charger / doesn't turn on
    • 20984
    Re: HP 15-n027sa DA0U92MB6D0 not detecting charger / doesn't turn on
    +3V comes from PQ35 . Check that and PU6
      • 20984
      double post
      • loser18
        • Nov 2013
        • 274
        Yeah, but +3V is suspend voltage & it should come only after MAINON & SUSON...
          • 20984
          yes i know, last night you said you had 1.8V ,so i assumed you were testing pin 11 while switching on.
          • loser18
            • Nov 2013
            • 274
            OK...
            So I've phoned my customer to ask him how did this happen. He said it was caused by faulty adapter (broken cable). I've immediately checked AD_ID & it reads only 1V...Also EC8 was blown, but it's been replaced...Does anyone know if the 1V on AD_ID is correct voltage? I think it should be around 7-8 volts...
            • loser18
              • Nov 2013
              • 274
              Yep, the correct voltage should be around 0.75V...I think 19V has been pumped in to AD_ID rail & it fried U14(KBC)...Will update once replaced...
                • 20984
                yes its 0.75v as you found out. https://www.elvikom.pl/hp-15-n027sa-...on-t53186.html
                Do you have a programmer to flash the KBC dump .
                • loser18
                  • Nov 2013
                  • 274
                  Yes...Already did it...Also replaced SPI chip...Pls note that there's only one 4MB SPI on my mobo...
                  • Stevie2001
                    • Apr 2018
                    • 183
                    • irland
                    #29
                    Stick to basic use dc power supply to power the board fix it from thier. Once the board is fix turn your self towards adapter save tkme that way
                      • 20984
                      Yes.. the EC ia at U11. Glad you got it fixed. For future reference the bq24725A is compatible with BQ24728 .
                      • loser18
                        • Nov 2013
                        • 274
                        It's not fixed yet...BIOS didn't help...Waiting for new IT8528E & will post results once replaced...
                        • loser18
                          • Nov 2013
                          • 274
                          OK guys...
                          It's been a long time. The laptop is fixed now. I've replaced KBC & everything is working as it should be, however I've had some problems, which I'll explain below.
                          #1 Heads up:
                          My original KBC / IO chip was IT8528E EXS . I've ordered AXS & after replacement laptop was completely dead (not even 3 blinks on charging LED). I was never ever thinking the last 3 digits/numbers would make any difference (datasheet also describe them only as a "TRACKING CODE") but after digging some forums I've found out it's actually firmware number as well. Ordered IT8528E EXS & laptop seemed to be completely fixed. So just to let you know, next time you'll be replacing IT8528E or any IT KBC, buy the same "TRACKING CODE"
                          #2 Heads up:
                          After the KBC replacement & windows installation everything was working OK except battery charging. When I've started it, BIOS reported straight away the battery needs to be replaced,press enter, blah blah. First I thought my soldering job with KBC was not 100% & MBCLK data is not communicating properly (because I knew battery is OK), however that was not the case. The problem was I've tried another BIOS dumps, but once It's been re-flashed back to my original dump, battery is charging & also reporting OK. So just to let you know again, use your own dump if possible or it may be dependant on DMI information. Not sure.
                          Anyway...Thanks to you all mates...I hope this info will help to anyone with quanta U92 mobo....
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            #33
                            The info about suffix AXS and EXS being not compatible is a lesson for all of us. thanks for updating us.
                            • Stevie2001
                              • Apr 2018
                              • 183
                              • irland
                              #34
                              When i ordered the first time i was looking at them code ignoring the ITExxxxxx and it works
                              • simo
                                • 27
                                OK guys...
                                #1 Heads up:
                                #2 Heads up:
                                Thanks a lot, you helped me to solve the same issue with the same symptoms
                                • incorrect
                                  • Nov 2017
                                  • 22
                                  • Greece
                                  #36
                                  so,back to this thread,i have the same issue.
                                  but my kbc is ITE 8518E. is this kbc programmable or not?
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    #37
                                    ITE8518-Non Programmable
                                    • incorrect
                                      • Nov 2017
                                      • 22
                                      • Greece
                                      #38
                                      the same source says that ITE8528E is not programmable aswell but this thread says the opposite.
                                      • nikolayu
                                        Dell Latitude 5420 wont turn on when charger is connected
                                        by nikolayu
                                        I have Latitude 5420 that it's working fine on battery but when it's plugged on USB C charger it wont turn on.
                                        Battery is charging fine. Also, if I connect the charger while laptop is on, everything is fine, it will charge.
                                        The same thing if I connect to other USB C port.
                                        Charger is OEM
                                        03-13-2024, 12:34 PM
                                      • vdrokko99
                                        MBP wont turn on Only green light on charger
                                        by vdrokko99
                                        I have a similar problem... I got an old MBP for free, but wont turn on... Only green light on charger. I measured these voltages. If i try to do an smc reset using keyboard, nothings happen, wont go out the green led. I dont know how to continue, please help me.
                                        SMBUS_SMC_BSA_SCL 3.5V
                                        SMBUS_SMC_BSA_SDA 3.5V
                                        12-01-2024, 12:18 PM
                                      • ktmmotocross
                                        HP 650 G1 - works only with battery+charger but not detecting battery
                                        by ktmmotocross
                                        Hello.
                                        Have this HP 650 G1 that works ONLY when battery first and then attach charger. otherwise it not work with charger or battery only.
                                        i cannot fing what is wrong with it. ACDET - ok, ADP_A_ID - 3.3V ACPRESS, Mosfets looks ok. even when working board dont see battery . data link on battery is ok 3.3V
                                        this charging circuit is hard. anybody knows what to measure?
                                        HP 650 G1
                                        6050A2566401-MB-A04
                                        sn - 5CG52238HF...
                                        02-11-2024, 12:13 PM
                                      • pajdek
                                        Lenovo Y700-17ISK turn on and off
                                        by pajdek
                                        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                        09-20-2023, 02:49 AM
                                      • flat-earther
                                        ASUS X54H laptop thinks it's always charging even with charger unplugged
                                        by flat-earther
                                        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                        Windows also shows ''Plugged in'' when charger is not connected.
                                        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                        If I let battery run out and say it has 3% Windows will...
                                        06-24-2025, 09:32 AM
