Not powering on starts led blinks 4 times then off
  • Stevie2001
    • Apr 2018
    • 183
    • irland
    Re: Not powering on starts led blinks 4 times then off
    Originally posted by SMDFlea
    just replace the isl and other parts, take it from there .
    Hi sir thanks for the kind reply.
    I checked PU3 boardview and what i discovered is pin19 CSIP is short with gnd i set multi-meter on continuity mode and set the black probe on gnd and with red probe i checked each leg and come to know that pin19 is conflicting with gnd buzzing.
    Can that be the cause.
    • mielta
      • Apr 2015
      • 368
      Hi
      Remove PU3 and then messure again if is there short to gnd.
      it can be also PD10 or in the VA2 line
        • 20709
        take off the isl and test the pin/pad 19 on the board again
        • Stevie2001
          • Apr 2018
          • 183
          • irland
          Thanks gys will do now.
          Will laptop turn on without this ic just wanted to no.
          • Stevie2001
            • Apr 2018
            • 183
            • irland
            Removed ic the pin19 short is gone.
            I tried starting it up without the ic still when i press power the orange light blinks 4 times.
            Going back to thermal camera when i press power button i se ic u13 gets little heated when blinking orange led stops heat goes away
            • mielta
              • Apr 2015
              • 368
              Hi
              First change the ISL
              • Stevie2001
                • Apr 2018
                • 183
                • irland
                #27
                Originally posted by mielta
                Hi
                I need to order one il get back once i fitted new one
                • Stevie2001
                  • Apr 2018
                  • 183
                  • irland
                  #28
                  The ic pin19 when i took it out i tried to se if gnd and pin19 beeps and it dont also with the ic out on the pads i tested same its ok soon as i put that ic back in it beeps pin19.
                  What do you make of it.
                  • Stevie2001
                    • Apr 2018
                    • 183
                    • irland
                    #29
                    I have 0v on few areas and i think my target problem may be
                    winbond wpce775la0dg
                    Can that cause loss voltage orange blinking light
                      • 20709
                      If you start probing around the kbc you might short it out. I`m almost certain the replacemnt isl will fix it ,and if it doesn`t let us know,and we`ll try and help further.
                      "Patience is a virtue"
                      • Stevie2001
                        • Apr 2018
                        • 183
                        • irland
                        #31
                        Ok sir i will be patient get new isl thank you so much.
                        • Stevie2001
                          • Apr 2018
                          • 183
                          • irland
                          #32
                          Ok update OMG.
                          I have a blue light wow.
                          You guys was right it was the isl.
                          I had another notebook with isl inside got it out replaced and bang soon as i connected the dc the blue light on power button appeared so i pressed it and main power led blue comes on.
                          Thank you so much for all the help you provided to all those who replied love you guys.
                            • 20709
                            You`re welcome
                            • chaos-theory
                              Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                              by chaos-theory
                              I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                              Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                              03-14-2025, 05:37 PM
                            • Biruslapio
                              Panasonic P58V11B 8 and 12 blinks error "fix"
                              by Biruslapio
                              Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                              Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                              04-13-2021, 07:13 AM
                            • drscoot
                              HP X360 convertible battery blown fuse error, not charging
                              by drscoot
                              HP Modelnumber: 14-dh0061nb​
                              This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                              The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                              I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                              And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                              All these 3 batteries are charging...
                              12-15-2023, 05:54 AM
                            • Andre Gilbert
                              by Andre Gilbert
                              Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                              Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                              11-20-2024, 08:52 PM
                            • cmlewis89
                              LG 47LB5DF blown power supply board
                              by cmlewis89
                              Hi folks,
                              I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                              09-03-2024, 07:50 PM
