Trouble Locating Shorted Component
  • Alidaco
    • May 2018
    I've been trying to revive my 2015 Dell XPS 13 (9343). So far I've been able to locate a short to ground on the 1.35v power rail on the system side.
    After doing a bit of research online I came across Louis Rossman's videos on finding short circuits where he applied an expected voltage to the power rail and then feels around the board to see which component gets hot.
    Unfortunately, the board only takes around 0.8 amps at 1.35 volts. Ultimately, 1.35 volts at 0.8 amps isn't enough to make the component hot, and I'm hesitant to crank it up further and apply a voltage higher than what the rail is rated for.
    Any thoughts? I appreciate any help you guys are able to offer!
    -Coleman
  • R_J
    • Jun 2012
    • 9607
    Re: Trouble Locating Shorted Component
    That would tell me that there is NO short to ground at that point. If there was a short the current would be a lot higher. I would not apply a higher voltage. that would not be good.
    • Alidaco
      • May 2018
      Thanks for the reply, RJ. So a resistance of less than 2 ohms would be normal on a power rail that carries low voltage?
      I'd considered the fact that it might not be shorted, but after measuring a bunch of other points on the board, I couldn't find any resistances lower than 50 ohms or so. That's why I thought the 1.4 ohms or so might be a short.
      • R_J
        • Jun 2012
        • 9607
        It does seem low but it might be normal. Do you get any voltage on that line during normal operation? what supplies that 1.35 volts? maybe there is a problem with the source not outputing the 1.35 normally.
        I found this schematic, maybe it is helpfull in some way
        It looks like 1.35volts is used by almost everything
        1.35 seems to be derived from B+ via pl600 coil and PQ600/PQ601 fets and should be able to supply at least 4.48 amps
        • piernov
          • Jan 2016
          • 4439
          • France
          +1.35V is the RAM voltage. 1.4ohms seem way too low to me for this rail. I've seen only the CPU VCore getting that low and on Pentium 4 only, the others are at least a few ohms in my experience.
          You should try desoldering PJP600/PJP601 to check which side is shorted, or if PJP600/PJP601 are not labelled/present on the board, remove PL601.
          • grimacelord
            Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
            by grimacelord
            Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
            After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
            I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
            10-24-2024, 12:31 PM
          • nagkiller
            Asus Geforce Cerberus GTX1050TI-O4G-DIS short circuit in the FBVDDQ rail
            by nagkiller
            Hello everyone!
            This grafic card came for repair, but when I connected it to the motherboard, the board would not start (short circuit in the 12V rail).
            After removing some PLs to isolate the short in the 12V rail, I got to PML1/PML2, according to the BoardView reference.
            Even injecting a voltage of 1V0 and a current of 3A in the FBVDDQ rail, for example, the voltage drops to 0V20 and none of the components heat up.
            The attached boardview file is very similar to this grafic card, which I am basing the repair on.
            I would like some...
            05-10-2025, 09:19 AM
          • techrepairheide
            Gaming laptop Clevo NH79EP with short on 5VS-rail
            by techrepairheide
            first of all I want to apologize for my bad English, but I try to give my best.
            Customer brought me a laptop, which is charging the battery (when the dc-jack is connected) but don't power up when the power-button was pressed down. Only the white LED lights up, and you can hear a short noise in same interval when power-button was pressed and hold for longer timer. The customer changed already battery and dc-power-adapter.
            For this laptop the correct shematic is the service manual "Clevo NH50ER NH57ER NH50EPS NH57EPS - 6-71-NH5S0-D02 Schematic"....
            10-13-2024, 02:49 PM
          • karlp028
            MSI B360M Bazooka short on 3VSB rail
            by karlp028
            I have an MSI B360M Bazooka with a dead short on the 3VSB rail (and VDD33 which is connected). The ethernet controller chip (UL3 in boardview) was getting very hot, so I thought that was the culprit. But after I removed it, the short remained. When I added 5V standby power again, I noticed the ground pad where the ethernet controller had been was getting very hot, as was the nearby hole for an m2 standoff.z
            I haven't found the problem component(s) causing the short yet (no thermal cam). Does the heating of the ground pad mean it should be something near there?
            04-01-2025, 07:20 PM
          • femin
            Lenovo LOQ 15IRH8D2 RAM power rail short
            by femin
            Could you help me to find the Voltage rail IC PU301 model
            Multimeter continuity model shows short after the PU301 IC and to the whole ram slot is short to ground
            07-10-2025, 03:34 AM
