Working on a board that i was able to bring back to life. The only issue I have now is there is no schematic (even paid sites).. The board was destroyed by the fan connector I was able to fix and re-solder by finding the trace's i.e 5v , GND , ETC.,,, however, I cant find out where the fan signal goes to the EC it8527e.. Is there anywhere to find the proper pin ,, if so I could fix the laptop without the fan warning..??????
pin out for it8527e
Re: pin out for it8527e
See if this helps, see page 34 FAN_TACH0 Pin47 -
lol,,, good news so far.. So I took a best guess based on what trace was visible (not much at all) and turns out that IT IS hooked to pin 47 already... The problem is the power on CPUFAN1 ill try that on pin 30.. The ground is correct and I do get 5 volts,,, so hopefully 3 out of 4 is correct ill try the last one real quick... Thanks a million for the schematic..Comment
Channel: BIOS Requests ONLY!
Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
by corrizeHello, I search this connector (oxydated).
It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
Do you know how to find this connector please ? What is the exact name for find it ?
by sam_sam_samThis Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...-
by reformattFull part number on board is ODIN N ADL DDR4 UMA MB 213264-1. Can't seem to locate this even on paid sites as it's still very new model. There is however an earlier version of the board (203128-1)which looks pretty much the same from what I can see elsewhere but all are behind paywalls.
Technically still under warranty. Customer was told by tech support to disconnect the battery, and for some reason destroyed the connector on the battery itself. He sent it to Dell, saw the damage, and they refused to look at it and sent it back to him. So here we are.
PL4501 and PL4551...-
- Loading...
