Dell inspiripon 1545 WiFi cannot browse
  • akande
    • Dec 2017
    • 278
    • Nigeria
    This is worrisome , my inspirion 1545 has full WiFi connection but I cannot surf the net with it, I reload the with different OS no luck, change WiFi card, use dell assistant tool, no luck can someone help me out pls
  • akande
    • Dec 2017
    • 278
    • Nigeria
    Re: Dell inspiripon 1545 WiFi cannot browse
    Is there no solution to this problem
    • azhar2006
      • Feb 2018
      • 27
      • iraq
      Set the date and time of the computer from the BIOS settings.
      The problem is not in the Wi-Fi card.
      Replace the battery cmos
      • akande
        • Dec 2017
        • 278
        • Nigeria
        Thanks for reply, the time in bios is correct but let me change the change the close and feed u back
        • petehall347
          • Jan 2015
          • 4427
          • United Kingdom
          try ipconfig command
          • KillerFlash
            • Apr 2018
            • 8
            • Phillippines
            Check your IP address and your firewall
            • akande
              • Dec 2017
              • 278
              • Nigeria
              Thanks for reply, have put the firewall off, changed cmos battery, problem persist it will just browse 2-3 hrs and show no Internet secured
              • akande
                • Dec 2017
                • 278
                • Nigeria
                All the option given didn't surf my problem, so I decided to reload the OS and redrive it, after the it browse for some minute and stop again. Pls I need perfect solution to this dell WiFi issue
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Have you tried with another laptop on your MiFi ? I've seen similar devices needing a restart after long periods of use.
                  • petehall347
                    • Jan 2015
                    • 4427
                    • United Kingdom
                    log into MiFi and check settings .. ip something like 198.192.1.1 .. see if it stays logged in after wifi stops .
                    • petehall347
                      • Jan 2015
                      • 4427
                      • United Kingdom
                      another thing to try is use your phone as a hotspot and connect to that instead of mifi
                      • petehall347
                        • Jan 2015
                        • 4427
                        • United Kingdom
                        plus you flush the dns to see if that helps ..cant harm nothing trying
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          This looks more like a bad wifi receiver. I had a laptop that acted similar, and the tracert and/or the ping utility, reported packet loss! (IIRC)
                          The wifi card may have a bad solder joint or a bad cap...
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • akande
                            • Dec 2017
                            • 278
                            • Nigeria
                            With this problem persist
                            • akande
                              • Dec 2017
                              • 278
                              • Nigeria
                              Ji have Try 2 Different Working Card,But Problem Persist
