Alienware LA-C912p Issues
  • knoxy
    • Nov 2017
    • 6
    • US
    I have an alienware motherboard seems to be a problem child. When I first received it, a capacitor on the board was shorted to ground preventing even being able to plug in the charger. Once the cap was replaced it worked great.
    ...Until later that later that evening it started behaving strangely with issues arising it the following order:
    1. Stating it was charging without actually charging. (Would still boot it either adapter or battery unplugged)
    2. Fans spun at 100% all the time.
    3. I7 6700HQ Cpu would only run at its minimum clock of 800mhz
    4. Near complete short to ground (1-2ohm) returned.
    This time when voltage is applied to either of the main inputs, the CPU gets red hot with all mosfets surrounding it getting either warm or hot as well...
    Without a schematic or board view available does anyone have any suggestions?
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Alienware LA-C912p Issues
    First, measure again the capacitor which you have replaced to check whether it is shorted or not. Where have you observed the 1-2Ohm resistance?
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      These laptops (along with most, if not all other Dells) automatically throttle the CPU down to minimum if the power adapter is not detected properly. You may have a problem in the adapter cable or jack (if the board is still working right now).
      A working TV? How boring!
      • ken0011
        • Nov 2018
        • 11
        • 3W
        I also have the same problem. Can you post a picture indicating where is the location of the capacitor? thanks
        • ub6ib969
          Alienware M17 R3 M/B LA-J521P charging issues
          by ub6ib969
          Alienware m17 R3 which charges using USB-C however it does not charge using PJPDC1 (dc jack)
          • disconnected PJPDC1 and measured voltage on Pins 1-6 19V (19V_ADPIN)
          • once connected into PJPDC1 PIN 1-6 1.20V (19V_ADPIN)
          • Diagnostic tests does not detect charger.
          Has anyone have this issue before?
          11-04-2024, 02:32 PM
        • armands0212@gmail.com
          Alienware 13 power/freeze issues
          by armands0212@gmail.com
          hi guys.i have problem with alienware 13 r1.Basically its running ok as long as it is on power supply and i dont put it on sleep(if put it on sleep it wont wake up just freeze and need to do hard shut down),if running only on battery than it freeze straight away on account login screen.
          But if i disable nvidia gpu and running only on intel hd graphics than no problems at all.
          Look like laptop previously have been overclocked as base speed is 2.4ghz but should be only 1.7ghz and if i try disable overclocking in bios nothing changes.
          i tried to adjust power managment...
          12-20-2022, 09:23 AM
        • z32KRAzY
          Alienware 15 R3 Motherboard Issues Help Plz!
          by z32KRAzY
          Hi, I have an Alienware 15 R3 that I just bought a new motherboard for from ebay.. I have been trying to figure out this issue for 2 weeks already and I've decided I need help from the pros.
          Laptop specifics:
          Model : Alienware 15 R3
          CPU : i7 6820HK
          GPU : Nvidia GTX 1080 Max Q
          RAM : 16GB PC4-19200 (8GB x 2)
          STOR : 256GB M.2 SSD + 1TB HDD
          Motherboard : Compal LA-D753P Rev 1.0
          Problem : The laptop runs fine with most things, even GPU/CPU stress tests seem to run without problems for extended periods of time. BUT...
          08-07-2022, 06:08 AM
        • kain0007
          Alienware X15R2 P111F black screen after updating windows.
          by kain0007
          Hi Masters.
          I have an Alienware x15R2 laptop that went black after updating Windows.
          Could someone help me repair my bin?
          Alienware X15R2
          ST: 1CJY6M3
          Thank you very much for your support....
          10-09-2025, 02:20 PM
          Alienware 13 R3 Notebook Specification for Upgrade or Repair
          This specification for the Alienware 13 R3 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13 R3 boardview and 13 R3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Alienware 13 R3 Notebook...
          09-06-2024, 06:42 AM
