Macbook air A1370 - 820-3024-B - Chime loop
  • Gold7even
    • Sep 2013
    • FRANCE
    Hello to all, this time i meet a symptom that drive me mad !
    I have a macbook air 11" A1370 - Board id 820-3024-B (Core i5 1.6 11 (Mid-2011) that is stuck in a boot system loop (chime loop) this computer start and i hear the chime sound that repeat endlessly with only a white screen.
    Sometime (rarely) it chime normally (one time) and i can see the blinking folder (this computer doesn't have a ssd for now) after a certain delay.
    I realized that if i unplug the lvds cable i does not have any more chime loop… i test on an external screen with adapter but only white screen with sometime (rarely) the blinking folder !
    The keyboard seems to not working, (the caps lock doesn't lit) and all keyboard command doesn't respond (Commande ⌘ + Option + P + R etc…) Only the power button do the job !
    At first i was thinking the problem is due to an EFI corruption, So i reprogram the efi chip many time (with different bios file) and the symptom is always the same, no evolution...
    Because of the keyboard problem, it was impossible to reset the nvram.
    Now i was thinking there was a possible shortcut somewhere, do you have any tips related to this motherboard where to put under my investigation ?
    The motherboard is corrosion free, the water damage indicator is intact and the board seems untouched but i don't know the past of this laptop…
    Have you ever experienced the same symptoms and successfully repaired the motherboard ?
    Thanks in advance for your feedback,
    Thomas from France
  • dellxps15
    • Feb 2014
    • 1597
    • italy
    Re: Macbook air A1370 - 820-3024-B - Chime loop
    any usb keyboard should work fine... just unplug yours, then power on shorting pins and then try reset nvram by pressing right combination, if i remember good, option is alt, cmd is control and the other key is windows key.
    check if it do that reset option 2 times for completing nvram then release bottons.
    • Gold7even
      • Sep 2013
      • FRANCE
      Thanks for your response, i have already try to disconnect the internal keyboard and use an external apple usb keyboard but with no luck (caps-lock doesn’t lit) and still no response to cmd ⌘ + Option + P + R or Option (⌥) to select the boot device !
      • Gold7even
        • Sep 2013
        • FRANCE
        Also if anyone has a "ME Region clean" efi bin dump for my motherboard i am interested.
        • amrahmed47
          • Jan 2019
          • 6
          • egypt
          i ned faile bios .bin
          • zeypibytescss
            • Apr 2019
            • philippines
            please upload....
            • Gimi
              • Aug 2015
              • 75
              Hi. Have you tried loading os from an external drive?
              • No Lan
                [Macbook pro A1708] [Boot loop] [Trackpad ?]
                by No Lan
                Hey everyone,
                Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                05-24-2025, 03:09 PM
              • saulini
                macbook air a1932 no display but can hear the battery chime
                by saulini
                Hello guys...
                I bought MacBook from a garage sale the owner told me that the MacBook was dead and it did not display nothing, at first I thought it was related to a t2 problem so I did the bride OS with my other MacBook I was able to revive it but it did display the apple logo but on the apple configurator the lock symbol was there upon further inspection the MacBook did make the chime sound every time I disconnected the power cable but still it did not show any display also the caps key was able to light up, with nothing else to do i remove the motherboard and found the following...
                09-08-2023, 09:47 PM
              • nikolayu
                MacBook Air A1932 internet recovery loop
                by nikolayu
                I have A1932 that is going to internet recovery every time.
                i tried nvram and smc reset but it looks that MacBook is not reacting to that.
                i tried to restore it through DFU but it restarts in the middle of process and Apple Configurator does not show any error, just stays like in progress.
                keyboard is working because I can connect to WiFi but internet recovery always fails with 2100 or 2003 error.
                also won’t open option to boot from usb device.
                and I noticed that is not possible to turn off the MacBook. It’s always turning on by itself.
                07-22-2025, 02:55 AM
              • Comp_Pro
                Macbook Air 820-00165 Static Chime Sound
                by Comp_Pro
                Hello all,
                I have a weird issue to solve here. This macbook air came in showing a black screen even though the backlight was lit. The display was not the issue as I tried another known good display. Upon trying to restart it, sometimes it boots up but freezes at the login page. More commonly however, the macbook will give the chime sound but then get stuck repeating the sound. The first chime sound is normal but the subsequent chimes sounds are crackly. Voltages seem normal, no liquid damage. I did find a blotch of something near one of the crystals on the other side of the CPU...
                11-02-2023, 03:23 PM
              • envym
                by envym
                Hi everyone!
                06-27-2025, 08:54 AM
