I have elite book Hp6930p battery not detected Nido someone help on this pls
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by huzoHi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
by mrkmpnHello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,... -
by mkdjHello everyone,
Mark and model: ASUS X571
Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
Tests already made:
- Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
- I have removed... -
by gurujihello
I have a samsung laptop galaxy book 3 np940xfg board is BA41-03013a venus3-14.The laptop turns on when connected with battery but the battery has random charging it charges till 70% and then it starts going in reverse the percentage.removed the board and disconnected the battery and attached the 65watt adapter the boot rom for tbt 3v is absent and the laptop does not power on. another strange issue in both the usb-c ports when you reverse the cable the power indicator light does not glow.they using a common dual port CYPD6228-96bzxi and 2 thunderbolt chips intel JHL8040R.
my... - Loading...
