820-2327-a long beep on startup and black screen
  • opethfan
    • Feb 2015
    • 81
    • Italia
    Hi
    i have this macbook pro:
    - 1 beep on startup and black screen
    - sometimes it boot without problem
    i try to replace ram and hdd without luck
    can someone help me?
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: 820-2327-a long beep on startup and black screen
    you should do a number of tests and discover more symptoms. is any IC hot on the board? when does it boot normally?
    • opethfan
      • Feb 2015
      • 81
      • Italia
      there isn't any hot ic.
      After black screen it boots normally when i wait
      in fact:
      - sometimes it do a long beep and black screen
      - sometimes only black screen
      - sometimes after black screen it boot from drive normally
      - sometimes after black screen nothing happen but fan continue spins
      • BMCappelletti
        Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
        by BMCappelletti
        Hi everyone.
        Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
        Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
        Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
        02-18-2025, 12:22 PM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • reformatt
        by reformatt
        Yesterday, 08:37 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
