i have hp 6930p that shows plug in charging when connected to power source, but the batteryy will keep discharging gradually instead . hav change a new good batt no luck . i need assistance on this pls
					HP elie book 6930p charging issue
 I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
 To assist with troubleshooting, I'm attaching two power circuit schematics:- Power
			by drlarsenHello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
 I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
 On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
 After some hours, the battery status did not improve. Restore via DFU did not help.
 I connected the power adapter to a Kill-a-Watt...
			by ahmarzoHave Dell la-j081p laptop with battery issue.
 First the laptop was not charging pqb25 was short after changing pqb25 and pqb26 the laptop starts charging and runs properly on charger but battery it shutdown after 10 seconds.
 And when powered on only on battery the laptop turns off after 8-10 second without giving display.have tried another battery on another working laptop and it's working fine
 I have changed charging ic and pqb25 ,pqb26 and pqb13.
 When adapter is disconnected the laptop stays on battery for 8-10 sec then abruptly shutdown everytime.
 This is the link...
 I have a problem identifying a problem on this MacBook Air A1466 with board 820-00165.
 A customer came in with a problem, the laptop was not charging. Otherwise, it works fine - runs from a battery without an issue. The battery is original, the customer also provided his original charger.
 However, when I was diagnosing the issue, I turned the laptop off, checked the board, etc. When I put everything back together, the laptop was charging (I inserted the charger and then turned the laptop on). After unplugging the charger and plugging it back,...
			by koby058Hi gentlemens,
 I have this vibo book that got a bit of water. After clean up the boarf. It works on adapter and work on battery, but it is not charging.
 I have checked first and second mosfet They look fine. Replaced 9241H to a new one but it is still not charging. Battery accept charge directly from power supply.
 Can you advice on things that i can check?
 Motherboard have no schematic available online....
- Loading...
