la-j081p charging issue
  • ahmarzo
    • Mar 2015
    • 171
    • india
    Have Dell la-j081p laptop with battery issue.
    First the laptop was not charging pqb25 was short after changing pqb25 and pqb26 the laptop starts charging and runs properly on charger but battery it shutdown after 10 seconds.
    And when powered on only on battery the laptop turns off after 8-10 second without giving display.have tried another battery on another working laptop and it's working fine
    I have changed charging ic and pqb25 ,pqb26 and pqb13.
    When adapter is disconnected the laptop stays on battery for 8-10 sec then abruptly shutdown everytime.
    This is the link for schematic https://www.badcaps.net/filedata/fetch?id=2077307.
    Please help thanks in advanced
  • mon2
    • 14543
    Have you tested another known good battery on this laptop?
    Remove all power. Meter in resistance mode. Measure the resistance between pins #1 and #2 on the charger IC @ PUB01. Test directly on the IC pins with the meter probes. Checking if the full path resistance matches the schematic value. If they do not, the charger IC believes there is a fault in the battery pack and powers down. The battery may be just depleted but the adapter is not charging the battery.
    What is the resistance in ohms?
    • ahmarzo
      • Mar 2015
      • 171
      • india
      Thank you mon2.pin 1 and 2 was showing 200 ohms as resistor value was changed after changing it to 0 ohnes the laptop is working on battery.thanks again
      • mon2
        • 14543
        Good. Suggest to use the values as defined by the schematic otherwise the excessive current draw from the battery pack will not be sensed properly. The charger IC is expecting to have onboard the values showing in the schematic.
        • ahmarzo
          • Mar 2015
          • 171
          • india
          Yeah changed from same part no scrap motherboard.thanks for the suggestion.
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • serious_electron
            Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
            by serious_electron
            Hello Everyone!
            I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
            06-28-2025, 02:57 PM
          • piernov
            Laptop battery charging circuit
            by piernov
            1. Some theory
            1.1. Introduction
            Almost every laptop has a charging circuit of some sort, that does a few things:
            • Manages switching between AC adapter and battery power
            • Manages battery charging and generates power rail to charge battery
            There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
            • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
            • Narrow VDC (NVDC)
            Texas instrument has a nice overview of these technologies with some more details at https:...
            11-15-2020, 01:31 PM
          • yaya3gmax
            Laptop Power Issue – Works on Battery, Fails on Adapter Load
            by yaya3gmax
            Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
            Symptoms:
            • Laptop works normally on a pre-charged battery.
            • Battery does not charge when adapter is connected.
            • Without battery:
              • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
              • Speakers “pop” when power cut occurs indicating harsh sutdown.
              • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
            08-21-2025, 07:16 AM
          • drlarsen
            MacBook Air M1 A2337 battery/charging issue
            by drlarsen
            Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
            I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
            On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
            After some hours, the battery status did not improve. Restore via DFU did not help.
            I connected the power adapter to a Kill-a-Watt...
            07-17-2025, 02:35 PM
