ASUS G751JY nvvdd not turning on
  • myth77
    • Feb 2017
    • 380
    • Croatia
    The laptop turns on but nothing on the screen. I checked every part of the motherboard and everything is fine except NVVDD is not turning on, no voltage after G_PWR_SRC_NVVDD mosfets, they are not turning on. I borrowed two same working motherboards and cheched resistence on all the DGPU nets and only difference i found was on FBVVDQ...On working motherboards the resistence is arround 90 ohm, and on not working its arround 38 ohm...but the funny thing is that on FBVVDQ net the voltage is present.
    So...questions...the lower resistence on FBVVDQ net indicates that one or more gpu memory moduls are bad? if so, how to determine which one?
    And why NVVDD is not turning on? is it because FBVVDQ is bad? I couldnt find anywhere what is the power on sequence order...which is first? fbvvdq or nvvdd? and are they depending on each other to turn on?
    Help please
    Boardview attached.
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: ASUS G751JY nvvdd not turning on
    Leave FBVDQ alone and focus on NVVDD to fix. how much resistance on PL8501?
    • myth77
      • Feb 2017
      • 380
      • Croatia
      arround 9 ohm...it is the same as on the working motherboard
      • myth77
        • Feb 2017
        • 380
        • Croatia
        Update...
        I was comparing two motherboards, one working one not working, plug the charger, used a multimeter...and going step by step...
        first of all i found datasheet for PU8501 pwr controller UP1661P for nvvdd. i checked the voltage on first pin and yes i had on both motherboards...second pin, the one that should open mosfet no voltage on not working motherboard. Then i checked the third pin (enable pin p-nnvdd_en) and only 0.5v reading. On working one it is arround 3v. Also same on fourth PSI pin...
        So i was going back throught the boardview...why the P_NNVDD_EN_10 is not receiving/trasnfering voltage...so i go through the boardview...and came across this area...as far as i can see through this mosfet q7101 and 0 ohm resistor R7130 should power P_NNVDD_EN_10 and pwr controller..but on working motherboard i have voltage on that second mosfet pin and dgpu_pwron network but on not working i dont have, i have arround 13 v on pins 5 and 6- DGPU-DSG-SW
        And from here i am lost...can someone take a look on boardview and suggest what/where to check next?
        THank you very much
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          what voltage on pin 2 and 3 of Q7101?
          • myth77
            • Feb 2017
            • 380
            • Croatia
            both 0V, on pin 2 and pin 3 ther is 0V.
            Pin 5 and 6 DGPU_DSG_SW 13.5V
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              now measure voltage on all pins of Q7105.
              • myth77
                • Feb 2017
                • 380
                • Croatia
                pins 5 and 6 (DGPU_DSG_MAIN) 13,4v,
                pin 3 DGPU_PWR_ONMAIN 0v,
                pin 2 N43278125 0,05V
                • caspian
                  • Oct 2015
                  • 1591
                  • Laptop
                  are the other voltages the same as you reported on the following thread?
                  www.badcaps.net/forum/showthread.php?t=65496
                  • myth77
                    • Feb 2017
                    • 380
                    • Croatia
                    Yes.
                    • caspian
                      • Oct 2015
                      • 1591
                      • Laptop
                      It would be better if you continued the old thread. you mentioned: 0.1v on 3v3_aon net,
                      If so, many voltage rails cannot be present on the board. please measure 3v3_aon again.
                      • myth77
                        • Feb 2017
                        • 380
                        • Croatia
                        yes, you are right, sorry
                        i double checked +3V3_AON is 0.09V
                        • caspian
                          • Oct 2015
                          • 1591
                          • Laptop
                          How much voltage and resistance on PL8001 and PL8200?
                          • myth77
                            • Feb 2017
                            • 380
                            • Croatia
                            NOT WORKING MOTHERBOARD:
                            PL8001 i have arround 60 ohm and 1.7V
                            PL8200 i have arround 85 ohm and 1.08V
                            PL8001 i have arround 80 ohm and 1.77V
                            PL8200 i have arround 113 ohm and 1.08V
                            • caspian
                              • Oct 2015
                              • 1591
                              • Laptop
                              do the CPU and PCH get warm on the faulty mainboard?
                              • myth77
                                • Feb 2017
                                • 380
                                • Croatia
                                yes, they are getting warm.
                                • caspian
                                  • Oct 2015
                                  • 1591
                                  • Laptop
                                  probably, either CPU or PCH is faulty. CPU is the most probable. I wish it was not soldered to the board.
                                  • myth77
                                    • Feb 2017
                                    • 380
                                    • Croatia
                                    when i say warm i dont mean like really hot, i can touch it with finger and sense the heat, but not overheating...
                                    Also, can i measure resistence on pch and cpu to ground and compare the measure with working motherboard? is it enough to conclude that cpu/pch is working?
                                    Also, can you explain it to me what part turns on +3v3_aon? i checked every part of the aon net and i cant figure what resistor/pwr/mosfet...transfers volts to +3v3_aon?
                                    Thank you!
                                    • frysu36
                                      Colorful rtx 3070 NVVDD-NCP81610 issue
                                      by frysu36
                                      hello everyone, I’m new here and apologize in advance if I did post in wrong section etc. currently I’m working on RTX3070 from colorful-igame advanced which has NCP81610 in cherge of NVVDD (vcore). Long story short, I connected to his SMBus with elmorlabs EVC2SE and dumped all regs. In register 0x23, status fault, I got bit 0 - UVP_fault and bit 3 - CLIM_fault. I already replaced NCP but it’s behaving the same way. When I toggle EN to GND (r22 10k on q5 pin3 side) I am able to start NVVDD and all other rails like FBVDD and PEX aslo starts no problem, GPU is pulling 1.5A from lab psu, all...
                                      02-16-2024, 03:02 PM
                                    • Sparklingx
                                      HP 450 g1 keeps turning on even tho shutdown/sleep
                                      by Sparklingx
                                      HP 450 g1 keeps turning on even tho I shutdown/sleep . one way to stop the turning on cycle is pressing the power button few seconds thus force powering it off. But then sometimes it does not turn on at all but next day I try again to turn it on and it turns on....
                                      09-23-2024, 12:34 AM
                                    • khelane
                                      Satellite PRO A50-A Not turning on after turning off Windows
                                      by khelane
                                      Hello
                                      A device with specifications
                                      Toshiba Satellite PRO A50-A is here to replace the hard drive.
                                      The hard drive has been replaced and there is no problem, but there is another problem, but the customer does not care to fix the problem.
                                      The device enters Windows without any problem and works, even I put pressure on the CPU and graphics, but when I turn off the system through Windows, if I want to turn it on again, the system switches, but it turns off quickly within a second, and this routine continues. It is turning on and off within a second and soon it turns off....
                                      04-20-2023, 06:28 AM
                                    • Rabit
                                      VX3276-2K-mhd-2 Random Turning off
                                      by Rabit
                                      Recently staring turning off more often, brightens set at 50% - monitor back side in PSU area is very warm to touch, also at front left corner getting hot.
                                      When changed brightens set at 30% no longer turning off , and no longer I can feel any heat in this areas.
                                      This can be signs of bad capacitors causing overheating PSU ?
                                      06-17-2024, 09:30 AM
                                    • shakib200
                                      Dell latitude E7240 not turning on if adapter plugged in
                                      by shakib200
                                      Laptop turns on only on battery but if I plugged the adapter with battery, it is not turning on. After turning on the laptop using only battery (no adapter plug in), then plugging the adapter everything works fine also charging ok. Anyone have any clue what’s wrong?...
                                      03-31-2024, 12:55 PM
