A1286 No backlight
  • m4a2t0t
    • Mar 2013
    • 276
    A1286 No backlight
    I have a Macbook Pro A1286 with a core i5 and it has no backlight after reballing the GPU.
    The laptop would not display any high resolution content. After clicking on the username the laptop would start loading and then display a grey screen. It would not load recovery, internet recovery or any utility.
    The laptop will now login and displays content fine but it has no backlight.
    Any suggestions on what to look at first? Anyone have schematics or board viewer?
    I've tried re-plugging all the cables, SMC reset and tried the brightness buttons. Anything I might be overlooking?
    EDIT: FOund board viewer https://www.badcaps.net/forum/showthread.php?t=44413 . Will check Backlight filter.
  • audiomodder
    • Dec 2017
    • 54
    Re: A1286 No backlight
    Search 820-2915-A schems and boardview in an internet search. you will come up with stuff.
    Did you seriously attempt a GPU reball without even the schematic? Wow....gutsy.
    Once you get the schem, check out the backlight driver circuit and look at the EN pin. Also, the CLK and DATA (coming from the GPU) lines with 100k pullups to the LVDS are important and will keep your internal display from working if they are shorted or missing.
    There is also a small backlight fuse which is always worth checking. But get on those schematics first.
    • alihomee
      • Dec 2012
      • 1570
      • malaysia
      u can find fuse and light ic near the fan connector
      • m4a2t0t
        • Mar 2013
        • 276
        Thanks. The fuse is open. Guess I should start at the beginning of the circuit instead of the end.
        • audiomodder
          • Dec 2017
          • 54
          yep, check the EN stuff first, then the IC output, then both sides of fuse. If all is OK only THEN replace the fuse.
          • tblam
            • Nov 2019
            Hello! (I am new to forums so I hope I'm not doing anything wrong writting on someone else's post!)
            I also have this board, no GPU reballed just the original thing. Fuse is 12.53V on each side and I have 3.3V on BKLT_RST but 0V on BKLT_EN. So I guess I have to change IC U9600 but where can I see if there is power going to it first? I don't want to unsolder that kind of thing for the first time and find out later that it was not the problem xD
            Thanks for your help!
            • piernov
              • Jan 2016
              • 4435
              • France
              820-2915 = dead GPU.
              • barry101
                Apple A1286 Mid 2012 MacBook Pro 820-3330 LCD Backlight issue
                by barry101
                Hi everyone.
                I hope someone has some suggestions on how to proceed with this issue.
                I have an Apple A1286 2012 MacBook Pro with 820-3330 Logic board. My customer purchased this from me in full working condition. Unfortunately, it overheated on him due to being left running on his bed.
                Investigation showed the LCD Backlight was not working (had a latent image and external monitor worked), the battery was no longer functioning (system couldn't read it or charge it) and the Samsung 850 EVO SSD was dead (not seen by finder or disk utility). Quite the trifecta....
                03-24-2022, 03:25 PM
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
              • DanPoka
                Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                by DanPoka
                I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                02-15-2025, 05:05 AM
              • Comp_Pro
                No Backlight Macbook A1990 820-01041
                by Comp_Pro
                Hello all,
                Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                Tests performed:
                There is no backlight even with a good screen.
                Backlight IC is receiving the correct support voltages.
                Fuse F8400 ok
                Current sense resistor R8400 ok
                Backlight IC is receiving 3.3V on enable pin.
                Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                Backlight IC receiving 5V from PP5V_G3S
                Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                05-06-2024, 10:23 PM
              • cheebster
                iPad Pro 12.9 5th Gen Backlight Issue
                by cheebster
                Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                Anyone...
                05-20-2025, 09:17 AM
