macbook 820-2850-A no PM_SLP_S4
  • audiomodder
    • Dec 2017
    • 54
    hey folks,
    working hard on this one and I'm pretty stuck. PP5V_S5 was originally shorted dead to ground because of a bad cap (C6213). In the process of finding that, I injecting 5V into the rail to see what would heat up...which didn't help much.
    I removed the audio amps, removed and replaced U7300, removed and replaced U5930 (accident).
    My problem appears to be no PM_SLP_S4 (its stuck low, though not shorting).
    PP1V05_S5 - 1.04V
    PP3V3_S5 - 3.3V
    PPBUS_G3H - 12.57V
    PP3V42_G3H - 3.34V
    I injected 5V into PP5V_S5 and it draws very little, so I think the short is no longer the issue now that the cap was removed. But maybe it shorts when EN lines are activated? I notice that it is ~10ohms to GND when magsafe is plugged in. My scope shows nothing pulsing on the lines either.
    Should I remove U7300 (TPS51116) again ? Or remove U6201 (audio decoder)? these are the best candidates for 5V_S5 issues...though I'm not sure if I should be looking for something else..
    Thanks!!
  • audiomodder
    • Dec 2017
    • 54
    Re: macbook 820-2850-A no PM_SLP_S4
    Small update,
    turns out I have a working board of the same type to take measurements from. With diode checks everything matches up, 3.99-0.4 for PP5V_S3 and PP1V5_S3 from U7300 (TPS51116) checks out.
    Problem seems to be when power applied, PP5V_S3 measures ~8ohms to ground. Yuck.
    Then, *magically* one time (out of the 50 times power cycling) it actually booted! This was not able to be repeated.
    So I am thinking it is a cap problem. I went and removed every single cap connected to PP5V_S3...no dice. I'm thinking is have to be something shorting internally when an EN pin is active on one of the chips then. What a mess.
    Should I just take out the audio encoder and U7300? Or maybe inspect around U7201 more to see if there's something missing? No water damage though, it is a clean looking board. Oh how I wish so hard there was a in like fuse with PP5V_S3 so I could at least rule out U7201 as the problem.
    • audiomodder
      • Dec 2017
      • 54
      Another update:
      So I did a little trick to test PP5V_S3: I removed the resistor to PM_SLP_S4 (R7912) and ran a 100K resistor from the R7912 input to PP3V3_S3 output. That way the 3.3V working rail doubles as an ENABLE for the 5V rail of U7201.
      That totally worked. Now I know my 5V is not the issue, or at least it highly unlikely.
      but PM_SLP_S4 still isn't there and I don't know why. Can someone point me in the right direction on this one? I'm hoping it isn't an issue with U1800. It looks like U1800 generates its own clock signals (built in PLL) but I don't know which voltages / signals it needs present to activate PM_SLP_S4 .
      • piernov
        • Jan 2016
        • 4439
        • France
        PCH needs RTCRST#, SRTCRST#, INTVRMEN# and RSMRST# for it to initialize. The first 3 signals should always be present.
        RSMRST# is not present when the machine is turned off on battery, it may be present with AC adapter connected and machine off (I don't know about Apple). It must be present as soon as the machine tries to turn on, and must be present before PWRBTN# goes high again. This is managed by the embedded controller, the SMC in Apple devices.
        PWRBTN# triggers the PCH to change power state (S5→S4→S3→S0).
        Also the PCH will need to communicate with the SPI ROM.
        • audiomodder
          • Dec 2017
          • 54
          Thanks for the SUPER informative reply piernov! Thats exactly the kind of info I've been needing for a while...
          So just for the hell of it I tried another 85W charger and...it boots + works now!! Whatthehell apple. The other charger had green light, rock solid 12.6V, 3V42, etc.. so *shrug* I'll test it in a couple days again to make sure it isn't something else. But I sure am glad I didn't pull all the PP5V_S3 parts. I still have to replace those BGA amps I removed though... >_<
          • envym
            by envym
            Hi everyone!
            06-27-2025, 08:54 AM
          • Flasman90
            Macbook Pro DFU Restore Issues
            by Flasman90
            I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
            - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
            - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
            08-30-2025, 10:27 AM
          • tobeend
            Bypass mdm macbook m2 ventura
            by tobeend
            1. RESET MACOS WITH IPSW
            a. Power off MacBook, press and hold the power button to enter Recovery
            b. Open Disk Utility, remove Macintosh HD
            c. Reboot, connect to the network to Activate Mac.
            d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
            d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
            e. Release the other keys, but keep holding the Power key for another 10 seconds
            f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
            05-26-2023, 07:18 AM
          • SarcasticOP
            General question about MacBook power rails for repair.
            by SarcasticOP
            I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
            • PPBUS_G3H (12.6V-12.8V)
              • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
            • PP3V42_G3H (3.42V)
              • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
            • PPVRTC_G3H (3.3V)
              • This
            12-12-2024, 05:50 PM
          • obelix24
            A2941 Macbook air 15” - 5V 0a
            by obelix24
            I’m working on one macbook air 15” m2 that was water damaged.
            keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
            i’ve put macbook in shelf and order new screen so i can fully repair it.
            Now i got the screen and macbook stays at 5v 0a.
            i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
            i don’t have schematics so i don’t know where to start can someone help me?...
            03-27-2025, 01:19 PM
