[HP dv6-1304el] LP156WH2-TLQ1 backlight issue
  • onlyseries
    • Mar 2016
    • 14
    • Italy
    Hello everyone!
    My friend gave me his broken laptop and now I want to try to repair it.
    It is an "Hp Pavilion dv6-1304el" and the LED is "LG LP156WH2-TLQ1".
    There is a flash backlight when starting the laptop but it fast disappear and it's possible to see picture, only when using a flashlight. Connected to an external monitor works without problems.
    I have taken out the LED but I haven't saw nothing of unusual.
    If I buy a replecement broken led(also a different model like this LP156WH2-TLQA ) , can I take the backlight system from it or can it be a problem on the motherboard?
    Thanks!
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: [HP dv6-1304el] LP156WH2-TLQ1 backlight issue
    yes, in addition to the screen, it is also possible that the mainboard or the screen cable are faulty.
    • onlyseries
      • Mar 2016
      • 14
      • Italy
      If the backlight sometimes lasts for a few minutes (even about 30 minutes) and also, if I close and reopen the screen quickly (without closing it completely), the backlight will work again. (even if for a short while)
      Could it be that the problem is just about the cable? Or can't we completely rule out a problem with LCD electronics?
      Thank you for quick response
      • iplaypty
        • Aug 2017
        • 47
        • FLORIDA
        sounds like cable problem.
        There is a cheap easy way to fix, but you will not be able to control the light.
        check on youtube "electronic repair school backlight"
        https://www.youtube.com/watch?v=zBB1L5F-VZg
        I hope it helps
        • onlyseries
          • Mar 2016
          • 14
          • Italy
          I hope it helps
          Thank you very much for the video, very useful even just for personal knowledge!
          Now, unfortunately, I can't test it on my friend's computer, because I've returned it. He also warned me that it has now magically returned to work. (so I'm taking for granted that it's just a false contact, as in the video)
          • Cornito
            Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
            by Cornito
            Hello Team,
            I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
            Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
            Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
            08-08-2024, 08:09 AM
          • cheebster
            iPad Pro 12.9 5th Gen Backlight Issue
            by cheebster
            Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
            Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
            Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
            The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
            Anyone...
            05-20-2025, 09:17 AM
          • Cornito
            TCL 65C715 backlight issue
            by Cornito
            Hello team,
            I'm back with another topic.
            It's a 65C715 TCL tv with backlight issue.
            But the problem is a bit strange.
            When I took this tv from the marketplace backlight didn't work but picture was ok.
            Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
            Putting all back together the tv worked fine for weeks. => Contact issue??
            Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
            06-09-2024, 02:24 AM
          • Riananyaina
            MacBook A1708 820-00840-A backlight issue
            by Riananyaina
            Hello Everyone ,
            today I'm coming to you regarding my issue which is no Backlight .
            I have image on my screen but no light .
            The macbook was one that I bought few month ago that I used with an external screen . Now I started to do some analysis on the MB which my limited knowledge .
            First thing is that it suffered from liquid damage . The fuse was not ok when I openned it the first time . But I already changed it after testing that there is no short to ground on this line .
            Please find below few informations which can help for the analysis...
            04-24-2023, 05:03 AM
          • fuzzyrunner
            Samsung LN52B750U1FXZA - Backlight Issue
            by fuzzyrunner
            Hello All!
            So here is the issue I am having. When everything is plugged in as normal, the TV turns on and I get a quick flash of the backlight. After that the backlight never turns back on but the rest of the TV works fine. If I pull the PWM pin from the cable between the main board and power board the backlight turns on and the tv works "normally". If it is plugged in I get nothing. I did do a factory reset but that didn't solve my issue. When everything is plugged in normally I get .6v at start up and continues rise over about 10 seconds. (~.6v then ~.8v then ~1.8v...
            02-28-2024, 07:36 PM
